A reminder for 3.0.3 which is planned for 15 December. I could take care of the release build.
Is there any bug fix or major features to be apply before the release ? Any languages to add from Transifex ?
I propose to have an IRC meeting next Tuesday 11:00 CET if anything needs to be discussed for the release.
Cheers.
Francois
3.0.3 is still panned for today. Let me know if there is any blocker ?
If none, I’ll make the release this afternoon after some more db migration tests.
Cheers.
Francois
2015-12-05 9:23 GMT+01:00 Francois Prunayre <fx.prunayre@anonymised.com>:
Cheers.
Francois
On 12/15/15 09:48, Francois Prunayre wrote:
If none, I'll make the release this afternoon after some more db
migration tests.
Am i the only one seeing the 'full view' broken ?
https://github.com/geonetwork/core-geonetwork/issues/1350 is giving me headaches since some days..
Landry Breuil
Mouton a 5 pattes du CRAIG
Hi Landry,
I had some issues also with DC and associated tab (https://github.com/geonetwork/core-geonetwork/issues/1348) but got them fixed.
Is your error related to a specific record ?
Francois
2015-12-15 10:33 GMT+01:00 Landry Breuil <breuil@anonymised.com>:
migration tests.
Am i the only one seeing the ‘full view’ broken ?
headaches since some days…
Landry Breuil
GeoNetwork-devel mailing list
On 12/15/15 10:35, Francois Prunayre wrote:
Hi Landry,
fixed.
Nope, i'm seeing this even on the templates coming from iso19139 schema. Errors during geonetwork bootstrapping, and at runtime when trying 'full view' on the 'Template for Vector data in ISO19139 (preferred!)' MD.
Landry Breuil
Hi Landry,
fixed.
And the more debug logging i add to classes in services/src/test/java/org/fao/geonet/services/metadata/format/groovy/template, the more i have the impression that all those NodeFactory classes are *never* called.
On another note for 3.0.3 you might want to eventually merge https://github.com/geonetwork/core-geonetwork/pull/1346 & maybe https://github.com/geonetwork/core-geonetwork/pull/1347
Landry Breuil
Hi François,
the migration process fails if you try to migrate from a version prior to v3.0.0 because a Java migration is not found.
In the migration config file [1], the migration is v300.SetSequenceValueToMaxOfMetadataAndStats but in the Java code the package name is commented. Is a good moment for fixing it?
[1] https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/config-db/database_migration.xml#L97
[2] https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v300/SetSequenceValueToMaxOfMetadataAndStats.java#L1
On Tue, Dec 15, 2015 at 11:03 AM, Landry Breuil <breuil@anonymised.com> wrote:
Hi Landry,
fixed.
Nope, i’m seeing this even on the templates coming from iso19139 schema.
Errors during geonetwork bootstrapping, and at runtime when trying ‘full
view’ on the ‘Template for Vector data in ISO19139 (preferred!)’ MD.
never called.
Landry Breuil
Vriendelijke groeten / Kind regards,
Juan Luis Rodríguez.
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
