Hi Geonetwork Users List
I have a question about the behavior of OAI/PMH harvesting.
I am harvesting from an OAI/PMH provider endpoint and the result in my geonetwork instance (I've tested in both geonetwork 2 and 3) is that the identifier that is being assigned is value of <identifier> instead of the value of the <fileIdentifier> in the metadata record that's being harvested.
<!-- e.g. xml from oai-pmh provider -->
<record>
<header>
<identifier>example-identifier-123</identifier>
<datestamp>2019-01-15T02:43:25Z</datestamp>
<setSpec>iso-aodn</setSpec>
</header>
<metadata>
<gmd:fileIdentifier>
<gco:CharacterString>90e010e3-d49f-44fc-8173-4a8ce396451c</gco:CharacterString>
</gmd:fileIdentifier>
</metadata>
</record>
Would someone be able to tell me if this is expected behaviour or should it actually be assigning the value from <fileIdentifier> ?
Thanks very much
George
University of Tasmania Electronic Communications Policy (December, 2014).
This email is confidential, and is for the intended recipient only. Access, disclosure, copying, distribution, or reliance on any of it by anyone outside the intended recipient organisation is prohibited and may be a criminal offence. Please delete if obtained in error and email confirmation to the sender. The views expressed in this email are not necessarily the views of the University of Tasmania, unless clearly intended otherwise.
