hello Wolfgang, François, and list :
I’ve looked at it a bit more with Jose Garcia, and we found :
(1) GeoNetwork did not send a outputSchema in its GetRecords request. This means that the default per the CSW202 spec should be used by the deegree server, which I think means we should receive results of type csw:SummaryRecord, as says François;
(2) GeoNetwork should actually put a “more preferred” ISO outputSchema in the request, if the Capabilities advertizes it (as does the deegree server’s Capabilities). Jose is committing a fix for this to GeoNetwork today;
(3) GeoNetwork can only handle GetRecordsResponse that contains SearchResults of type csw:SummaryRecord (CSW) or gmd:MD_Metadata (ISO). Other types, like the dc:metadata receivede from deegree, leads to the message “Skipped record not in supported format :” you got
(4) sending GetRecords requests to the deegree server with various outputSchema I get :
outputSchema=“http://www.isotc211.org/2005/gmd” → response: ISO records, correct
outputSchema=“http://www.opengis.net/cat/csw/2.0.2” → response: dc:metada, expected response: csw:SummaryRecord
Hopefully things are more clear ?
Kind regards
Heikki Doeleman
On Wed, Sep 30, 2009 at 12:18 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hello Wolfgang,
2009/9/30 Wolfgang Grunberg <wgrunberg@anonymised.com>:
GeoNetwork 2.41’s CSW harvester fails with our deegree 2.3pre CSW service
(http://75.101.143.247:8080/deegree-csw/services?REQUEST=GetCapabilities&version=2.0.2&service=CSW).
GeoNetwork’s GetRecords transaction request returns what appears to be a
valid CSW and Dublin Core GetRecordsResponse response. I have attached the
truncated response. This is a great improvement because deegree didn’t
accept the GeoNetwork response in the past.
However, GeoNetwork’s log gives me a “[geonetwork.harvester] - Skipped
record not in supported format : metadata” error and I am having
difficulties figuring out what the problem is.
It looks like dc:metadata elements are returned in deegree CSW
response. The harvester ask for a summary response with default schema
“Default value is http://www.opengis.net/cat/csw/2.0.2” CSW 2.0.2 spec.
I think we should get csw:SummaryRecord instead. Not sure if the
dc:metadata elements are 2.0.1 spec elements ?
Also if you set outputSchema=“http://www.opengis.net/cat/csw/2.0.2”
in the http://testing.deegree.org/deegree-csw/client/client.html you
get ISO records.
If you did not set outputSchema, you get an exception.
We discussed that point with Heikki, and the harvester is doing the following:
- GetRecords in summary format first to retrieve ids and date
- GetRecordById in ISO or OGC format to load the records.
More test needed.
Francois
What kind of response does GeoNetwork require?
Also, how do I enable more verbose logging in GeoNetwork?
Thank you for your time!
POST request to http://75.101.143.247:8080/deegree-csw/services :
<csw:GetRecords xmlns:csw=“http://www.opengis.net/cat/csw/2.0.2”
service=“CSW” version=“2.0.2” resultType=“results” startPosition=“1301”
maxRecords=“20”>
<csw:Query typeNames=“csw:Record”>
csw:ElementSetNamesummary</csw:ElementSetName>
</csw:Query>
</csw:GetRecords>
Response:
See attachment with a truncated response.
Wolfgang Grunberg
Arizona Geological Survey
520-770-3500
Come build with us! The BlackBerry® Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9-12, 2009. Register now!
http://p.sf.net/sfu/devconf
GeoNetwork-devel mailing list
