Hi
Has anyone tried to create a harvester in 2.10.3. I installed from jar and when creating a harvester I get the icon list empty, when saving the harvester I get this:
Unable to add a new entry
Error : error
Message : String index out of range: -1
Class : StringIndexOutOfBoundsException
Seem the icon has a value null and causes this error when saving in the database.
Maybe is my installation, but if someone can confirm? Seem a blocking if it’s confirmed.
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi, if you add logos, does it fix the error ?
Francois
2014-03-06 11:43 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com37…>:
Hi
Error : error
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Subversion Kills Productivity. Get off Subversion & Make the Move to Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and the
freedom to use Git, Perforce or both. Make the move to Perforce.
http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Hi Francois
I get the Logo panel completely empty. I can upload new images, and then the harvester get the new image and can save it.
But doesn’t seem a good solution. If someone can confirm that gets the same behaviour, I’ll create a issue for this.
Jose García
On Thu, Mar 6, 2014 at 11:57 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Francois
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2014-03-06 11:43 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
Error : error
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
