[GeoNetwork-devel] Harvesting and guest view [SEC=UNCLASSIFIED]
Hi list,
I have another question to do with harvesting. Once a dataset is harvested I seem to have to log into be able to view the records, a guest that has no username or password cannot view the metadata for these records. Am I able to set somewhere that on import records are publicly viewable? Or perhaps an addition for the next version.
For the time being I was just going to make an sql change to the operationallowed table but don’t know what groupid the guest account is associated with, indeed there seems to be no quest account on the default install.
Any help would be appreciated.
Michael Gannon.
Hi Michael,
harvested records reflect remote privileges. If you harvest using an account
you are willing to get confidential data so a metadata visible only to that account
is not visible to a guest user.
If a remote metadata is made public, when harvested it remains public and so it
is visible to a guest user.
Maybe someone has a better idea on how to keep privileges on confidential
metadata during harvesting.
The group assigned to a guest account is 'All' (that is, the internet one).
Hi list,
operationallowed table but don't know what groupid the guest account is
install.
Michael Gannon.
Hello,
I am not sure if the following is a bug or just my problem... I have created
metadata using the template iso19115 and then I´ve queried the catalogue
using the local search and works ok.. the problem comes up when I try
searching remotely (my local geonetwork) which returns nothing. Does anyone
know why?
Walter.
I've fixed it. I just had to set up some privileges.
Walter BARBERA
I+D Project Engineer
GTD SISTEMAS DE INFORMACIÓN
Pg. Garcia Fària, 17 E-08005 Barcelona
Tel.: +34 934 939 300 Fax: +34 934 939 334
www.gtd.es - walter.barbera@anonymised.com
-----Mensaje original-----
De: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] En nombre de Walter
Barbera
Enviado el: viernes, 04 de mayo de 2007 14:33
Para: geonetwork-devel@lists.sourceforge.net
Asunto: [GeoNetwork-devel] Remote search problem or bug?
Hello,
know why?
Walter.
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-devel mailing list
