Hi Francoise,
The test site on Crisalis is for testing CS/W services only. Now, the CS/W
code is complete and aligned but the site will not be updated as soon as
other parts will be finished.
I suggest you to test the harvesting between 2 nodes from the same
codebase.
Hi list, I'm getting on error when harvesting crisalis node. Problem is on
the isTemplate column of the Metadata table (see below). If I remove not
null constraint it works fine but isTemplate is not set to the default value
which is 'n'.
Any ideas ? My node is on http://dev.sandre.eaufrance.fr/gnthesaurus/ admin
/ admin
Francois
<nodes>
<node type="geonetwork" name="Crisalis" id="65">
<site>
<host>www.crisalis-tech.com</host>
<port>8081</port>
<servlet>geonetwork</servlet>
<account>
<use>false</use>
<username />
<password />
</account>
</site>
<searches>
<search>
<freeText />
<title />
<abstract />
<keywords />
<digital>false</digital>
<hardcopy>false</hardcopy>
<siteId>94e787ee-f765-4146-9565-988d95e90364</siteId>
<siteName>dummy</siteName>
</search>
</searches>
<options>
<every>5</every>
<createGroups>true</createGroups>
<createCateg>true</createCateg>
<oneRunOnly>true</oneRunOnly>
<status>active</status>
</options>
<info>
<lastRun>2007-02-12T12:38:34</lastRun>
</info>
<error id="error">
<message>You tried to add 'null' cell to column 'isTemplate' which is
declared as 'not_null'</message>
<class>MSQLException</class>
<stack>
<at class="com.mckoi.database.jdbc.RemoteDatabaseInterface"
file="RemoteDatabaseInterface.java" line="280" method="execQuery" />
<at class="com.mckoi.database.jdbc.MConnection" file="MConnection.java"
line="453" method="executeQuery" />
line="436" method="executeQueries" />
<at class="com.mckoi.database.jdbc.MStatement" file="MStatement.java"
line="193" method="executeQueries" />
line="167" method="executeQuery" />
<at class="com.mckoi.database.jdbc.MPreparedStatement"
file="MPreparedStatement.java" line="203" method="executeUpdate" />
<at class="jeeves.resources.dbms.Dbms" file="Dbms.java" line="256"
method="execute" />
<at class="org.fao.geonet.kernel.DataManager" file="DataManager.java"
line="295" method="setTemplate" />
<at class="org.fao.geonet.kernel.harvest.harvester.geonet.Aligner$1"
file="Aligner.java" line="221" method="handleMetadata" />
<at class="org.fao.geonet.kernel.mef.Visitor" file="Visitor.java" line="92"
method="handleXml" />
</stack>
</error>
</node>
</nodes>
