I think I have found a harvesting incompatibility when trying to execute a harvesting on gn2.6 which harvests from gn2.8 (maybe it has been already reported, but I couldn’t find it).
The fact is that harvesting fails, as it tries to connect to /geonetwork/srv/en/xml.search, which has changed to /geonetwork/srv/eng/xml.search in gn2.8.
The 2.8 server sends a HTTP/1.1 301 Moved Permanently response, but this is not handled at all by gn harvester, which tries to directly parse this response and then fails.
Could someone else confirm the problem? Do you have any workaround for it?
Best regards,
César
César Martínez Izquierdo
GIS developer
ETC-SIA: http://sia.eionet.europa.eu/
Universitat Autònoma de Barcelona (SPAIN)
