Hi list,
For harvesting OGC's WxS services I added the hierarchyLevel to the metadata. This may be useful to make a distinction between metadata for datasets and services.
It's just a small change in 2 XSL's and might be useful to others as well. What is the best way to get this change into the code base of Geonetwork (assuming that GN-community is willing to accept it)? Just emailing the XSLs to someone? Use trac? Or is the description of changes below sufficient already? I hope so :), but of course I am willing to do it the way you developers like best.
Thijs
===================== changes ======================
In web/geonetwork/xsl/conversion/OGCWxSGetCapabilitiesto19119/OGCWxSGetCapabilities-to-19119.xsl
after the characterSet element, add:
<hierarchyLevel>
<MD_ScopeCode
codeList="./resources/codeList.xml#MD_ScopeCode"
codeListValue="service" />
</hierarchyLevel>
In web/geonetwork/xsl/conversion/OGCWxSGetCapabilitiesto19119/OGCWxSGetCapabilitiesLayer-to-19139.xsl
after the characterSet element add:
<hierarchyLevel>
<MD_ScopeCode
codeListValue="dataset" />
</hierarchyLevel>
Hello Thijs, thanks for the input. It has been committed to trunk
(r1354).
Ciao. Francois
On lun, 2008-06-30 at 14:39 +0200, Thijs Brentjens wrote:
Hi list,
Thijs
In
<hierarchyLevel>
<MD_ScopeCode
</hierarchyLevel>
In
<hierarchyLevel>
<MD_ScopeCode
</hierarchyLevel>
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-devel mailing list
