What version of Geonetwork are you using?
Can you run:
geonetwork/srv/eng/q?fast=index&from=1&to=10
and make sure that result agrees with the 25,000 result?
Jesse
Sent: March 14, 2013 3:22 PM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Help: Records Number drops
Dear Developers,
I used the latest GeoNetwork codes to build a portal on Linux. There are about 100,000 records last night, but it shows only 25,000 records this morning. However, the database shows all records (100,000) records are still in database.
Is this a Lucene problem? I tried rebuild lucene but it will drop again. I wonder how I can fix it.
Thanks and best regards,
Kai
Joint Center for Intelligent Spatial Computing
703-395-2337
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
GeoNetwork-devel mailing list
Hi Jesse,
It now shows 56794. The file is as below:
http://ec2-54-234-123-20.compute-1.amazonaws.com/geonetwork/srv/eng/q?fast=index&from=1&to=10
It seems it changes over time.
Kai
703-395-2337
----- Original Message -----
Date: Thursday, March 14, 2013 10:29 am
Subject: RE: [GeoNetwork-devel] Help: Records Number drops
Can you run:
Jesse
*Sent:* March 14, 2013 3:22 PM
*To:* Devel geonetwork-devel@lists.sourceforge.net
*Subject:* [GeoNetwork-devel] Help: Records Number drops
Dear Developers,
There are
thismorning. However, the database shows all records (100,000)
records are
still in database.
again. I
Kai
703-395-2337
Oh`, The version of GeoNetwork is 2.9.0. I got the records from Github.
Kai
703-395-2337
Date: Thursday, March 14, 2013 10:53 am
Subject: Re: RE: [GeoNetwork-devel] Help: Records Number drops
Hi Jesse,
Kai
703-395-2337
> Can you run:
> Jesse
> *From:* Kai Liu <kliu4@anonymised.com>
> Dear Developers,
> There are
records
> records are
> still in database.
drop
> again. I
> Kai
> 703-395-2337
