[GeoNetwork-devel] Help to use the new "GeoNetwork data directory"
I try the last r8909 trunk version.
And try to use the new GeoNetworkDataDir setting.
I guess don’t understand well what need to do.
In the web.xml , I set the variable
geonetwork.dir /home/tomcat/geonetwork_data_dir
where the “geonetwork_data_dir” is the folder out of web space where I try to set the configs vlaue.
I leave the folder empty, because I think the webapps when it start fill the folder with all the defaults need.
After the start of the webapp (with a stop/start of the tomcat),
I see in the folder there is these resources:
config
codelist
schema_plugins
JZKitConfig.xml
schemaplugin-uri-catalog.xml
data
metadata_data
metadata_subversion
resources
htmlcache
index
nonspatial
eng
segments.gen
segments_1
But the big problem is that the geonetwork don’t start anymore.
The broser run until the webpp go in timeout.
Without show anything.
The logs don’t seem give any significative error.
Perhaps I need manually set any other variable or add manually some other file in these new folders ?
Many thx,
Andrea.
Andrea Peri
qwerty àèìòù
