[GeoNetwork-devel] Help with spatial searching
Hello all,
I read some of the previous posts and looked and changed my main-page.xsl by adding the quickWMS javascript. The client side javascript works fine, I have used the northBL…westBL as advised earlier in some posts exactly as they are expected in Lucene.xsl.
Now what is happening is that with the sample data that comes with geonetwork, my spatial searching doesn’t return any results, whereas there are some metadata that have bounding box values. What can be wrong?
Usman
Muhammad Usman Iqbal
PhD Candidate
EE 413A, G17
School of Surveying and Spatial Information Systems
The University of New South Wales
Sydney NSW 2052, Australia
Phone: +61 2 9385 4206
Fax: +61 2 9313 7493
Email: m.iqbal@anonymised.com
Web: http://users.tpg.com.au/usmani/
Hi Usman,
It’s a bit hard to say exactly what is happening…
  • Does the bounding box query work when you simply perform it from the URL?
  • if not, it may be that the geonetwork.jar would need to be updated with a version that incorporates the required change to the source code. The function was not available in version 2.0.2 code yet. Compiling a new geonetwork.jar can be done by checking out the V2_0_FIX2 version and using ant to build the jar file.
That should do the trick :slight_smile:
Ciao,
Jeroen
On Sep 5, 2006, at 12:44 AM, Usman Iqbal wrote:
Hello all,
Usman
PhD Candidate
EE 413A, G17
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-devel mailing list
