[GeoNetwork-devel] How to cuztomize interface of Geonetwork 2.6.4?
I want to customize the interface of Geonetwork 2.6.4, according to the
following:-
1. On main page there should be only a flashy buttons for uploading &
downloading data, search field and registration button.
When the upload/download button is clicked, the user should be navigated to
the registration page and after that, in case of downloading data - the user
must be able to see the list of all downloadable data, and in case of
uploading data - page should be opened for entering data.
In case of search the user should be navigated to a page containing all
search results.
In case of registration, the user should be navigated to registration page.
2. Is it possible to have all these functionalities ajax based?
Please could someone help me from where I should take the start, and for
this do i need to download the source code from svn?
Please guide me as we need to launch our portal by the end of this month.
Best Regards,
Saher
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-cuztomize-interface-of-Geonetwork-2-6-4-tp5005993.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Comments inline:
On Wed, Oct 3, 2012 at 8:39 AM, Saher Murad <sahermurad@anonymised.com> wrote:
following:-
    search results.
You can change the config-gui.xml to specify which service is the “home” service. So create a new service which is your home page. To do this:
  • edit config.xml and add a service
  • add service to user-profiles.xml
    look at another service defined in config.xml for an example on how to create a service
For branding you can change the header.xsl to change the header on virtually all pages. And you can change the geonetwork.css for more customizations
  1. Is it possible to have all these functionalities ajax based?
The source is now on github: https://github.com/geonetwork/core-geonetwork
You don’t need the source for these changes. you can build a war. Extract it. make your customizations and re-compress it and upload it to a server. Or just install it in a server and edit there.
I am planning on deploying geonetwork artifacts to maven central repository soon. That will allow you to make a maven project that can overlay your changes over the basic war and that way you can have a project with only your changes.
Jesse
Hi Jesse,
Thank you so much, I will try to follow as you have mentioned.
It would be of great help if you are going to deploy geonetwork artifacts to maven central repository.
Looking forward to it.
Kind Regards,
Saher
To: Saher Murad sahermurad@anonymised.com
Cc: geonetwork-devel@lists.sourceforge.net
Sent: Wednesday, 3 October 2012, 11:57
Subject: Re: [GeoNetwork-devel] How to cuztomize interface of Geonetwork 2.6.4?
Comments inline:
following:-
    search results.
Jesse
Hi Jesse,
After editing config.xml and adding services to user-profiles.xml, I'm able
to design a new user home page, please you also provide me some guidance
related to following question:
1. When a user click on a 'Downloads button' - that i have set on home page
- the user should be able to see the list of all downloadable data?
I will be very grateful for you help.
Best Regards,
Saher
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-cuztomize-interface-of-Geonetwork-2-6-4-tp5005993p5007991.html
On Thu, Oct 11, 2012 at 1:08 PM, Saher Murad <sahermurad@anonymised.com> wrote:
Hi Jesse,
After editing config.xml and adding services to user-profiles.xml, I’m able
  1. When a user click on a ‘Downloads button’ - that i have set on home page
  • the user should be able to see the list of all downloadable data?
What data is downloadable? The metadata? the data attached to a metadata? All data that is attached to any metadata?
Jesse
All that is attached to metadata.
For example, when we go to the following link, the user is able to see list of all the Metadata
http://localhost:8080/geonetwork/srv/eng/main.search
Now i want to display list of all those metadata that has some downloadable data.
Sent: Thursday, 11 October 2012, 16:51
Hi Jesse,
Jesse
there are a few methods you can do this:
  1. Do an ajax request for all metadata with an attachment and then process the result and display it with javascript
  2. Create a second service that is configured with a predefined search and create an xsl to display it. Then from your first page you can call that service for downloading the data.
For the first solution the query you probably want is:
http://tc-geocat0i.bgdi.admin.ch/geonetwork/srv/eng/q?fast=index&from=1&to=20&download=true
For the second solution you might be able to use the existing search:
http://localhost:8080/geonetwork/srv/eng/main.search.embedded?download=true&hitsPerPage=10&output=full
or implement your own.
You can look at the definition of main.search.embedded (in config-metadata.xml) for inspiration on how to do that.
Jesse
On Thu, Oct 11, 2012 at 2:04 PM, saher murad <sahermurad@anonymised.com> wrote:
To: Saher Murad <sahermurad@anonymised.com>
Hi Jesse,
Jesse
Thank you so much. First i will go for the 2nd method.
October 13, 2012 is our final launch, so i hope it would help me to do it.
Best Regards,
Saher
From: jesse.eichar [via OSGeo.org] <[hidden email]>
To: Saher Murad <[hidden email]>
Sent: Thursday, 11 October 2012, 17:34
Subject: Re: How to cuztomize interface of Geonetwork 2.6.4?
Jesse
Cc: [hidden email]
On Thu, Oct 11, 2012 at 1:08 PM, Saher Murad <[hidden email]> wrote:
Hi Jesse,
Jesse
Don’t let slow site performance ruin your business. Deploy New Relic APM
Deploy New Relic app performance management and know exactly
what is happening inside your Ruby, Python, PHP, Java, and .NET app
Try New Relic at no cost today and get our sweet Data Nerd shirt too!
http://p.sf.net/sfu/newrelic-dev2dev
GeoNetwork-devel mailing list
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/How-to-cuztomize-interface-of-Geonetwork-2-6-4-tp5005993p5008019.html
To unsubscribe from How to cuztomize interface of Geonetwork 2.6.4?, click here.
NAML
View this message in context: Re: How to cuztomize interface of Geonetwork 2.6.4?
Dear Jesse,
For the second method, i get the following message:
“This XML file does not appear to have any style information associated with it. The document tree is shown below”
What does it mean?
To: saher murad sahermurad@anonymised.com
Cc:geonetwork-devel@lists.sourceforge.netgeonetwork-devel@lists.sourceforge.net
Sent: Thursday, 11 October 2012, 17:33
Jesse
From: Jesse Eichar <jesse.eichar@anonymised.com89…>
Hi Jesse,
Jesse
THe url I gave you is the embedded url. It is intended to be embedded into another html page. If you want a standalone page use:
http://localhost:8080/geonetwork/srv/eng/main.search?download=true&hitsPerPage=10&output=full
Jesse
On Thu, Oct 11, 2012 at 3:46 PM, saher murad <sahermurad@anonymised.com> wrote:
Dear Jesse,
What does it mean?
From: Jesse Eichar <jesse.eichar@anonymised.com…189…>
To: saher murad <sahermurad@anonymised.com>
Cc:geonetwork-devel@lists.sourceforge.net” <geonetwork-devel@lists.sourceforge.net>
Jesse
Hi Jesse,
Jesse
Dear Jesse,
For http://localhost:8080/geonetwork/srv/eng/main.search?download=true&hitsPerPage=10&output=full it show all metadata that is even those which has no downloadable data.
I have also tried to create new service in config.xml, which is as follow:
And a created new xsl file “download-all-data.xsl”
Please could you guide me what i have to do in “download-all-data.xsl”
Sent: Thursday, 11 October 2012, 19:05
Jesse
Dear Jesse,
What does it mean?
From: Jesse Eichar <jesse.eichar@anonymised.com.189…>
Cc:geonetwork-devel@anonymised.comourceforge.net” <geonetwork-devel@lists.sourceforge.net>
Jesse
Hi Jesse,
Jesse
you might have to check the code in that case. I tested against 2.8.x
On Thu, Oct 11, 2012 at 4:24 PM, saher murad <sahermurad@anonymised.com> wrote:
Dear Jesse,
Cc:geonetwork-devel@lists.sourceforge.net” <geonetwork-devel@anonymised.comrge.net>
Jesse
Dear Jesse,
What does it mean?
Jesse
Hi Jesse,
Jesse
