I am trying to get metadata ID in the metadata service response from GeoNetwork for specified metadata. I have the UUID of the metadata.
Do you guys have any solution?
Shao
Shao
mmm, I think this has come up before with regards to setting permissions on items 'programatically' and I think the previous advice was 'scrape the response' from a metadata.show?uuid=XXX.
If there is a better way - please jump in
If not - maybe we need a stupidly simple service endpoint
metadata.to_id?uuid=XXXX
Terry
Sent: Saturday, 31 March 2012 4:03 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] How to Get Metadata Internal Identifier from UUID?
Shao
Why do you want the metadata ID ? This is just a database key, internal to the system. Metadata is identified by their UUID, I wonder what is your reason to want a GeoNetwork-internal primary key value ?
Kind regards
Heikki Doeleman
On Sat, Mar 31, 2012 at 1:19 AM, Terry.Rankine@anonymised.com wrote:
mmm, I think this has come up before with regards to setting permissions on items ‘programatically’ and I think the previous advice was ‘scrape the response’ from a metadata.show?uuid=XXX.
metadata.to_id?uuid=XXXXTerry
Subject: [GeoNetwork-devel] How to Get Metadata Internal Identifier from UUID?Hi all,
Do you guys have any solution?Thanks,
Shao
This SF email is sponsosred by:
Try Windows Azure free for 90 days Click Here
http://p.sf.net/sfu/sfd2d-msazure
GeoNetwork-devel mailing list
you may try in
geonetwork/WEB-INF/config.xml,
set <param name="skipInfo" value="n" />
restart app-server.
When calling
http://<hostname>/geonetwork/srv/en/xml.metadata.get?uuid=<uuid>
you will get a /gmd:MD_Metadata/geonet:info/id element in the response.
kind regards
Jørn-Vegard Røsnes
----- Original Message -----
Sent: Friday, 30 March, 2012 10:03:34 PM
Shao------------------------------------------------------------------------------
