I am initiating the use of the Geonetwork and have little knowledge of the Tomcat.
I am trying to make the Geonetwork run in Windows XP, with the Tomcat and the PostgreSQL, in port 8080.
I installed the Geonetwork and run in browser, but the InterMap is loading and it does not finish to load.
My computer run the Windows XP, and I made the installation in the following
way:
- I installed " jre-1_5_0_07-windows-i586-p.exe"
- I installed the complete version of " apache-tomcat-5.5.26.exe" , and I
configured the Tomcat for port 8080. - I installed the complete version of " geonetwork-install-2.1.0.exe"
- I initiated " GAST" e I configured:
Configuration/Jetty: (default)
→ Servelet = geonetwork
→ Port = 8080
Configuration/DBMS: (modified to…)
→ DBMS = PostgreSQL
→ Server = MyServerPostgreSQL
→ Port = 5432
→ Database = geonetwork
→ Username = MyUsername
→ Password = MyPassword
Menu → Options/Config: (default)
→ Server = Embedded
→ Acount = No Authentication - In the file “C:\tomcat\conf\server.xml” I made an modification:
Before tag I inserted the code:
After to restart tomcat, the Geonetwork appears in the browser, but the map
If somebody will be able to help me, will be grateful.
Marcelo G. Santana
marcelo@anonymised.com
Topos Informática do Brasil Ltda.
