[GeoNetwork-devel] how to retain the states of the http webrequests
Hi
I have used the code attached above (in c#.net) to get the authentication and i have executed it and now using the authentication i have to get the response from this url(“http://localhost:8080/geonetwork/srv/en/xml.metadata.get”) but the session is getting expired and reulting in 403 forbidden error pl have a look at my code and tell me where i went wrong
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Text;
using System.Net;
using System.IO;
public partial class Default2 : System.Web.UI.Page
HttpWebRequest webRequest = null;
protected void Page_Load(object sender, EventArgs e)
string RequestXML = “” +
“admin” +
“admin”;
string ServerURL = “http://localhost:8080/geonetwork/srv/en/xml.user.login”;
string ResponseXML = postRequest(RequestXML, ServerURL);
Textbox1.Text = ResponseXML.ToString();
string ServerURL1 = “http://localhost:8080/geonetwork/srv/en/xml.metadata.get”;
string RequestXML1 = “” +
“5915639e-777c-4339-93ad-c4037f2eeb77” +
string ResponseXML1 = postRequest(RequestXML1, ServerURL1);
private string postRequest(String RequestXML, string ServerURL)
int timeout = 90000;
int connectionLimit = 10;
string responseXML = string.Empty;
try
webRequest = (HttpWebRequest)WebRequest.Create(ServerURL);
webRequest.Timeout = timeout;
webRequest.KeepAlive = true;
webRequest.ServicePoint.ConnectionLimit = connectionLimit;
webRequest.Method = “POST”;
webRequest.ContentType = “Text/xml”;
byte byteArray = Encoding.UTF8.GetBytes(RequestXML);
Stream strm = webRequest.GetRequestStream();
strm.Write(byteArray, 0, byteArray.Length);
strm.Close();
HttpWebResponse webResponse = (HttpWebResponse)webRequest.GetResponse();
Encoding enc = Encoding.GetEncoding(“utf-8”);
StreamReader reader = new StreamReader(webResponse.GetResponseStream(), enc);
responseXML = reader.ReadToEnd();
reader.Close();
webResponse.Close();
catch (Exception ex)
throw (ex);
return responseXML;
(if you have any complications in looking at this code pl have a look at the attachment)
Thanks
Abinav Shankar
(attachments)
code.txt (2.27 KB)
