[GeoNetwork-devel] How to turn off map layers?
Hi to all fellow geonetwork developers!
I would like to switch off the map layers for developing. Only one solution
I have for now is to just configure a layer to some non responsive url. This
solution works but leaves the browser with tens of get request errors, which
are quite annoying while debugging with browser.
In config-gui.xml I tried these things, but they end up breaking the
javascript so the page will not load at all:
1) leave the layers element empty:
  <mapViewer options="{projection: 'EPSG:4326', maxExtent: new
OpenLayers.Bounds(-180,-90,180,90), units: 'degrees',restrictedExtent: new
OpenLayers.Bounds(-46,-18,-37,-8), minScale: 40000000.0 }">
  <layers>
  </layers>
  <scales values="[7500000, 5000000, 2500000, 1000000, 750000, 500000,
250000, 100000, 75000, 50000, 25000, 10000, 7500, 5000, 2500, 1000]" />
  <proj>
    <crs code="EPSG:4326" default="1" name="GCS (lat/lon)" />
  </proj>
  <servers>
  </servers>
</mapViewer>
2) Leave one empty layer element in the layers element:
  <layers>
     <layer />
  </layers>
  <proj>
  </proj>
  <servers>
  </servers>
</mapViewer>
Is there a more gracious solution that does not involve get request errors
or hacking the javascript that takes care of the map layers?
Thank you for your attention!
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-turn-off-map-layers-tp5093935.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
