Dear Shruti Babbar,
I'm sorry to hear that. Could you please provide us with details on the version of GeoNetwork you are using. We know there's an issue here with version 2.1 that has been fixed in the upcoming version 2.2. But I would like to be sure you indeed use version 2.1
Thanks and kind regards,
Jeroen
On Feb 22, 2008, at 7:52 AM, shruti_babbar17@anonymised.com wrote:
You are receiving this mail because shruti babbar
is sending feedback about the site administered by you at http://geonetwork-opensource.org.
The message sent was:
how can we upload any file from a local directory in the metadata creation form.please tell me the procedure.every time i am getting a error in uploading a file in this form.
GeoNetwork opensource Administrator
Jeroen Ticheler wrote:
Dear Shruti Babbar,
Jeroen
shruti_babbar17@anonymised.com is sending feedback about the site administered by you at http://geonetwork-opensource.org .
Jeroen,
We've been tripping over this too with IE7 - dear old IE appears to have a bug documented here http://dev.rubyonrails.org/ticket/11126
which needs a one line change to metadata-edit.xsl but which also requires commons-fileupload in jeeves to go to version 1.2.1 - I don't think I have Jeeves svn access so can't do that but I'll submit the fix to metadata-edit.xsl
It's a real showstopper for 2.2 so it'd be good to fix it
Simon
Sorry - not quite sure if that's what I meant to say
So I'll try again: It's an annoying bug for those forced to use exploder and I'm glad there is a fix and that others have made it available for us to get at
Simon
Simon,
If you have the fix (sorry, I write this in the train, so can't check the site you documented), I can apply it to jeeves and integrate it. It is indeed an annoying issue.
Ciao,
Jeroen
Dear Shruti Babbar,
Jeroen
Jeroen,
Simon
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
