Now, i am monitoring one local directory (such as C:\data) on the computer
where the geonetwork server installed. If new files are saved at the above
local directory, i want to use the ImportFromDir.java class to import the
whole local directory into database (such as jeeves, embedded in
geonetwork). I dont want to import them from the /srv/en/main.home webpage
using the batchimport GUI. I want to do that using program automatically.
How should I do?
Any suggestion will be appreciated!
Thanks in advance!
View this message in context: http://n2.nabble.com/How-to-use-ImportFromDir-class-to-achieve-importing-the-metadata-files-automatically--tp2885169p2885169.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hi Anthony, you could have a look to the local filesystem harvester
new in current RC or trunk if you're using those versions.
HTH.
Francois
2009/5/13 anthonyM <owenfan0715@anonymised.com>:
How should I do?
Thanks in advance!
Francois, Thanks for your reply.
Yes, I use the Geonetwork v2.2 now and I find that the ImportFromDir.java
class can complete the batch import through webpage.
But, I still dont know how to use this class to import the files which I
monitored into the database. I think if i could call the ImportFromDir
class (Init and Exec methods) correctly, I could achieve what I want. Is
there any example codes about calling this calss in JAVA, not XSL? I cannot
use XSL. thanks.
HTH.
Francois
computer
above
webpage
How should I do?
Thanks in advance!
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
GeoNetwork-devel mailing list
View this message in context: http://n2.nabble.com/How-to-batch-import-the-metadata-files-into-metadata-database-automatically--not-from-webpage%2C-but-using-codes-directly-tp2885169p2891020.html
