[GeoNetwork-devel] How to use PostGIS spatial index in 3.0.0 Urgent
Hi everyone,
Sorry for reposting this, but I really can't figure it out since there is
little documentation of 3.0.
Currently, I am able to connect GNK with Postgre, but I want to use PostGIS
for my spatial index because I have a large volume of datasets. I have
already created postGIS extension in postgre DB, but I don't think PostGIS
is being used (C:\Program
Files\geonetwork\web\geonetwork\WEB-INF\data\index), because the spatial
index file keeps getting larger as I add more data. So, can someone save me?
Best,
Cody
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-PostGIS-spatial-index-in-3-0-0-Urgent-tp5208696.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Did you try editing the postgres.xml file to change the driver to the postGIS one? Like on http://geonetwork-opensource.org/manuals/trunk/eng/users/admin/advanced-configuration/index.html#managing-the-database-connection-pool-through-apache-dbcp
Btw, for urgent things it is always good to have a support contract, even if it is an open source software :slight_smile: We are not always online and available.
María.
On Tue, Jun 2, 2015 at 5:41 PM, yongyao <yjiang8@anonymised.com> wrote:
Hi everyone,
Sorry for reposting this, but I really can’t figure it out since there is
already created postGIS extension in postgre DB, but I don’t think PostGIS
Best,
Cody
GeoNetwork-devel mailing list
Hi María,
Thanks for your prompt reply. Does GeoNetwork provide things like support
contract? If there is any, I will talk to my boss.
I tried to modify the postgres by using postgis driver, but the problem is
still there (GNK doesn't not use PostGIS for spatial index). Here is a
snippet from postgres.xml.
<bean id="jdbcDriverClassName" class="java.lang.String">
        <constructor-arg value="org.postgis.DriverWrapper"/>
</bean>
<bean id="jdbcURL" class="java.lang.String">
        <constructor-arg
value="jdbc:postgresql_postGIS://${jdbc.host}:5432/${jdbc.database}"/>
</bean>
And also, I tried to connect with PostGIS through JNDI, and I modified
jetty-env.xml (didn't touch jndi-postgres-postgis.xml), but I failed to
connect with DB.
Cody
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-PostGIS-spatial-index-in-3-0-0-Urgent-tp5208696p5208729.html
On Tue, Jun 2, 2015 at 8:38 PM, yongyao <yjiang8@anonymised.com> wrote:
Hi María,
GeoNetwork itself doesn't provide support. But there are many companies
around it that can help you with this. There is GeoCat (my company),
Titellus, Camp2Camp,...
</bean>
        <constructor-arg
</bean>
And with that configuration, the spatial index was still using the data
directory? Then maybe it is a bug.
connect with DB.
Probably that configuration is no longer used. Now all database
configuration is done on the config-db folder.
Cody
I think you need to import another file than postgres.xml in your srv.xml configuration file.
Try instead
<import resource=“…/config-db/postgis-alternate-datasource.xml”/>
On Wed, Jun 3, 2015 at 9:28 AM, María Arias de Reyna <delawen@anonymised.com> wrote:
Hi María,
GeoNetwork itself doesn’t provide support. But there are many companies around it that can help you with this. There is GeoCat (my company), Titellus, Camp2Camp,…
still there (GNK doesn’t not use PostGIS for spatial index). Here is a
And with that configuration, the spatial index was still using the data directory? Then maybe it is a bug.
jetty-env.xml (didn’t touch jndi-postgres-postgis.xml), but I failed to
connect with DB.
Probably that configuration is no longer used. Now all database configuration is done on the config-db folder.
Cody
Florent Gravin
Camptocamp - Chambéry
0479444492
Thank you María and Gravin! Finally, I figured it out. Just wanna share the
solution in case someone else may have the same problem.
First, in order to connect with Postgres, we need to modify two files:
1. C:\Program
Files\geonetwork\web\geonetwork\WEB-INF\config-db\jdbc.properties
2. C:\Program Files\geonetwork\web\geonetwork\WEB-INF\config-node\srv.xml
Then, you should be able to connect with Postgres successfully
Second, when you have large dataset, you may want to use PostGIS spatial
index instead of built-in data directory. In order to do this, you have to
modify postgres.xml file under C:\Program
Files\geonetwork\web\geonetwork\WEB-INF\config-db\. Below is my snippet,
<import resource="defaultJdbcDataSource.xml" />
    <import resource="postgis-alternate-datasource.xml" />
    <bean id="jpaVendorAdapterDatabaseParam" class="java.lang.String">
        <constructor-arg value="POSTGRESQL"/>
    </bean>
    </bean>
        <constructor-arg
Lastly, for some reason, jdbc.properties missed "port" attribute which is
needed by postgis-alternate-datasource.xml. So you have to add it by
yourself.
Yongyao Jiang
Ph.D. Student in Earth Systems and GeoInformation Sciences
NSF Spatiotemporal Innovation Center http://stcenter.net
Department of Geography and GeoInformation Science
George Mason University
4400 University Drive, Fairfax, VA 22030​
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-PostGIS-spatial-index-in-3-0-0-Urgent-tp5208696p5208977.html
