If I add ISO19139 sample data I get a record with the following title.
"Hydrological Basins in Africa (Sample record, please remove!)"
If I use the classic interface in English and French, I can search for
"Hydrological Basins in Africa (Sample record, please remove!) " and it will
find the record.
If I switch to the html5 interface - it will find the record if the
interface is in English but it will not find the record if the interface is
in French.
Is this a bug or is there a setting that needs to be adjusted to be able to
search for English content using the French interface.
Tested with Geonetwork 2.10.1
View this message in context: http://osgeo-org.1560.x6.nabble.com/HTML5-multilingual-search-issues-tp5070509.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
“Hydrological Basins in Africa (Sample record, please remove!)”
find the record.
in French.
Probably it is a bug, because I didn’t set up anything for that
Ian,
you should check multilingual settings which may impact the search results
http://geonetwork-opensource.org/manuals/trunk/eng/users/admin/configuration/index.html#multilingual-settings
but it should be the same in legacy and widgets UI I guess.
Francois
2013/8/2 ianwallen <ianwallen@anonymised.com>:
find the record.
in French.
Get your SQL database under version control now!
Version control is standard for application code, but databases havent
caught up. So what steps can you take to put your SQL databases under
version control? Why should you start doing it? Read more to find out.
http://pubads.g.doubleclick.net/gampad/clk?id=49501711&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
