[GeoNetwork-devel] I Want to join the Geonetwork developers ;)
Hello,
I work on a European project named Evoltree.
For the need of the project i have to do some customisations on geonetwork.
And i need also to add some supplemental functionalities.
It include :
1- The ability to manage thumbnail with url as like as the online resource
2- A simple workflow to know who have updated a metadata at least, with the
display of the information for the administrators and reviewers
3- A non sensitive cast Geonetwork search engine.
4- Customisation of the Authorisation management. We want that authors and
reviewers can set authorisations for groups they are not member as like as
the administrator.
Maybe some of this customisation can be interesting for the Geonetwork
community.
But to do it, i need to have read access to the head of the Geonetwork CVS.
And for the moment when i take the source head (
geonetwork.cvs.sourceforge.net ) , i get the 2.1.0 alpha release and not the
current 2.1.
I will also create user and administrator documentation for the Geonetwork
2.1 with the Intermap embedded and the Geoserver 1.5.3, and this on the
month coming.(before January)
Maybe that can also be interesting for the geonetwork community.
Fabien Bachraty
INRA Avignon
View this message in context: http://www.nabble.com/I-Want-to-join-the-Geonetwork-developers--)-tf4776595s18419.html#a13663719
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hi Fabien
GeoNetwork source code is available in the SVN as read access for everyone.
Just go to to have more info
http://sourceforge.net/svn/?group_id=72096
" This project's SourceForge.net Subversion repository can be checked out
through SVN with the following instruction set:
svn co https://geonetwork.svn.sourceforge.net/svnroot/geonetwork geonetwork "
in the trunk, you've the development (could be unstable)
in the branches, you've the 2.1.x version
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/branches/
You could also get the code from the installer (just tick the checkbox for
source code for that) if you want to start from a stable release.
Keep the devel list up to date to your new developments :!
HTH. Francois
Quoting FBachraty <Fabien.Bachraty@anonymised.com>:
Hello,
It include :
the administrator.
community.
current 2.1.
Fabien Bachraty
INRA Avignon
GeoNetwork-devel mailing list
Thank you very much Francois-Xavier
In fact my error was to use CVS source and not SVN.
That's work now :slight_smile:
Francois-Xavier Prunayre-2 wrote:
Hi Fabien
everyone.
geonetwork "
HTH. Francois
View this message in context: http://www.nabble.com/I-Want-to-join-the-Geonetwork-developers--)-tf4776595s18419.html#a13666398
Hi Fabien,
Please be aware that there is already administrator documentation available in subversion and that an updated user guide is about to be released. This may save you initial work :slight_smile:
Improvements to those are obviously welcome!
Ciao,
Jeroen
2.1 with the Intermap embedded a nd this on the
Thank you for this precision Jeroen !
Now i see documentation on the directory
Geonetwork/geonetwork/trunk/docs/manuals
So now i will wait the user guide release.
(In fact i haven't seen that this document were already present on the
current release 2.1)
Thank you very much :slight_smile:
Fabien Bachraty
Jeroen Ticheler-3 wrote:
Hi Fabien,
Ciao,
Jeroen
Geonetwork
on the
View this message in context: http://www.nabble.com/I-Want-to-join-the-Geonetwork-developers--)-tf4776595s18419.html#a13701716
