[GeoNetwork-devel] identifying ISO metadata profiles
It’s standard practice for communities to define profiles of existing metadata standards to enable interoperability. We are focused on ISO19139-encoded metadata, and developing a conformance class 1 profile for geologic information (http://lab.usgin.org/profiles/doc/use-iso-19139-xml-schema-describe-geoscience-information-resources).
The question is how to specify that a given metadata record conforms to a particular profile. In the context of ISO19115, it appears that the MD_Metadata.metadataStandardName is the intended place for this information. The scope note in ISO19115; 2003, Table B.2.1 states “name of the metadata standard (including profile name) used”. Obviously in order for generic clients to use this information there needs to be some convergence on the exact syntax for specifying the base standard and profile. However, GeoNetwork 2.4 (from subversion trunk 1/27/10) uses URI’s from the namespace declarations in an xml document to distinguish documents using different profiles, not the metadataStandardName (see details on the precise logic below). Thus, given the current code base, in order to introduce a new profile of ISO19139 (conformance class 1—no new elements added) that GeoNetwork will recognize, we have to put in a namespace declaration that serves to identify the profile.
Is this a widely used, undocumented convention for specifying profiles in ISO19139 metadata? Why doesn’t GeoNetwork use the metadataStandardName? My guess is we need a registry for metadataStandardName/profile strings. Its tempting to think that the URI’s geonetwork is using to identify profiles could just as well go in the metadataStandardName, perhaps with an ‘ISO:’ prefix of some sort.
steve
GeoNetwork schema detection logic
In GeoNetwork 2.4, we have determined that the schema detection algorithm works by first looking at the xml root element to detect FGDC, dc, the old ISO19115 xml, and CSW:Record metadata schema. If none of those match and http://www.isotc211.org/2005/gmd is not a declared namespace URI, then autodetect fails at this point.
If http://www.isotc211.org/2005/gmd is a declared namespace URI in the xml file (there may be many namespace declarations), then GeoNetwork attempts to match the xml file to one of the schemas defined in geonetwork\xml\schemas with the following logic:
If http://www.isotc211.org/2005/gmd is not the namespace URI for the root element in the xml being scanned, then GeoNetwork checks to see if the root element URI matches the ‘prime namespace URI’ defined by one of the geonetwork\xml\schemas; this ‘prime namespace’ is the target namespace in schemas<schema>\schema.xsd. If so that identifies the schema, otherwise autodetect fails.
If http://www.isotc211.org/2005/gmd is the namespace URI for the root element in the xml being scanned, then GeoNetwork checks the XML file’s other namespace declarations to see if any of the declared namespace URI’s match one of the geonetwork\xml\schemas prime namespace URIs. If so, then the matching schema is determined to be the file’s schema. If no matching schema is found, then the GeoNetwork ISO19139 profile is used, and what ever is in the metadataStandardName field in the imported metadata record is overwritten with “ISO 19115:2003/19139”, so if there is a profile specified, it is lost.
Stephen M. Richard
Section Chief, Geoinformatics
Arizona Geological Survey
416 W. Congress St., #100
Tucson, Arizona, 85701 USA
Phone:
Office: (520) 209-4127
Reception: (520) 770-3500
FAX: (520) 770-3505
email: [steve.richard@anonymised.com](mailto:steve.richard@anonymised.com)
Hello Steve,
2010/1/29 Stephen M Richard <steve.richard@anonymised.com>:
The scope note in ISO19115; 2003, Table B.2.1 states "name of the metadata
standard (including profile name) used". Obviously in order for generic
Hum, maybe some reasons :
* for the time being all ISO profiles which have been added to
GeoNetwork has a new namespace defined. But that's true that the use
of metadataStandardName could be a better approach for profiles. We
discussed that with Heikki also for the profil used in NGR project
which does not have a new namespace.
* but metadataStandardName is not mandatory in ISO, so what to do
when it's not provided ?
* also, looking to the ISO profil for France, there's no value
defined for the metadataStandardName. Which is maybe not a good idea !
So we should probably find a better way to handle profil with no
specific namespace.
Cheers.
Francois
steve
element URI matches the 'prime namespace URI' defined by one of the
schemas\<schema>\schema.xsd. If so that identifies the schema, otherwise
autodetect fails.
overwritten with "ISO 19115:2003/19139", so if there is a profile specified,
it is lost.
Stephen M. Richard
Phone:
FAX: (520) 770-3505
email: steve.richard@anonymised.com
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the
business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
GeoNetwork-devel mailing list
snip...
I would propose that if you're using some particular profile, specifying that in the metadataStandardName would be mandatory if you want people to know. If the root element is http://www.isotc211.org/2005/gmd:MD_Metadata, with no metadataStandardName specified, then the assumption would be that no profile is in use, and metadata conforms to ISO19139 (it is XML schema valid, no more...).
:slight_smile:
specific namespace.
I agree
Cheers.
Francois
Hi All,
The ANZLIC Metadata Profile version 1.1 uses the MD_Metadata namespace. This is because the ANZLIC Metadata Profile does not add nor exclude any ISO 19115 metadata elements. What it does do is make the MD_Metadata/fileIdentifier mandatory. This is checked in the ISO 19139 XML using Schematron rules. Hence, in the matter of compliance, an ANZLIC Metadata Profile XML metadata record is the same as an ISO 19139 XML metadata record.
Regarding the metadataStandardName. I believe that ISO 19139 should add an attribute to this element of type URL that allows a hypertext link to the actual XML implementation of the profile identified by the metadataStandardName and the metadataStandardVersion. This will allow users to find the validation XML - XSDs, Schematron etc. - and the profile documentation for the profile.
My two cents worth. ;--)
John
-----Original Message-----
metadata-bounces+john.hockaday=ga.gov.au@anonymised.com
[mailto:metadata-bounces+john.hockaday=ga.gov.au@anonymised.com
rst.com] On Behalf Of stephen richard
Sent: Monday, 1 February 2010 6:12 AM
To: Francois Prunayre
Cc: metadata@anonymised.com;
Subject: Re: [metadata] [GeoNetwork-devel] identifying ISO
metadata profiles
snip...
>> ISO19139 metadata? Why doesn't GeoNetwork use the
specifying
valid, no more...).
good idea !
:slight_smile:
> specific namespace.
I agree
> Cheers.
> Francois
>> tempting to think that the URI's geonetwork is using to
identify profiles
with an 'ISO:'
metadata mailing list
http://lists.geocomm.com/mailman/listinfo/metadata
_____________________________________
This List is brought to you by:
The GeoCommunity and The GISDataDepot
http://www.geocomm.com/ | http://data.geocomm.com/
Hello all,
John raises an interesting point here that makes me think of the MD_MetadataExtensionInformation/extensionOnLineResource element which is an onlineResource. We have been wondering lately about the difference between these two approaches to specifying an extension. The first clearly implies xml content. The second could support the kind of information John mentions…
Ted
Xlink Method:
<gmd:metadataExtensionInfo xlink:href=“[http://ngdc.noaa.gov/metadata/published/xsd/schema/resources/extensions/MD_MetadataExtensionInformation.xml](http://ngdc.noaa.gov/metadata/publishe
d/
nsions/MD_MetadataExtensionInformation.xml)” xlink:show=“embed”/>
CI_OnlineResource Method:
gmd:MD_MetadataExtensionInformation
gmd:extensionOnLineResource
gmd:CI_OnlineResource
gmd:linkage
gmd:URLlhttp://ngdc.noaa.gov/metadata/published/xsd/schema/resources/extensions/MD_MetadataExtensionInformation.xml</gmd:URL>
</gmd:linkage>
gmd:description
< nbsp; gco:CharacterStringNOAA National Geophysical Data Center ISO 19115 Extensions</gco:CharacterString>
</gmd:description>
gmd:function
<gmd:CI_OnLineFunctionCode
codeList=“http://www.isotc211.org/2005/resources/Codelist/gmxCodelists .x /a>”
codeListValue=“information”>information</gmd:CI_OnLineFunctionCode>
</gmd:function>
</gmd:CI_OnlineResource>
</gmd:extensionOnLineResource>
</gmd:MD_MetadataExtensionInformation>
</gmd:metadataExtensionInfo>
On Jan 31, 2010, at 4:05 PM, < day@anonymised.com">John.Hockaday@anonymised.com wrote:
Hi All,
My two cents worth. ;–)
Subject: Re: [metadat ntifying ISO
metadata profiles
snip…
* fo profiles which have been added to
GeoNetwork has a new namespace defined. But that’s true that the use
when it’s not provided ?
I would propose that if you’re u ile,
specifying
valid, no more…).
* also, looking to the ISO profil for France, there’s no value
good idea !
:slight_smile:
specific namespace.
I agree
Cheers.
Francois
br>
identify profiles
with an ‘ISO:’
_________ __ ___________
==== Ted Habermann ===========================
Enterprise Data Systems Group Leader
NOAA, National Geophysical Data Center
V: 303.497.6472 F: 303.497.6513
"If you want to go quickly, go alone.
If you want to go far, go together"
Old Proverb
==== Ted.Habermann@anonymised.com ==================
(attachments)
Ted Habermann.vcf (390 Bytes)
On 1/31/2010 4:05 PM, John.Hockaday@anonymised.com wrote:
Hi All,
I assume you mean http://www.isotc211.org/2005/gmd?
They both conform to the same xml schema, but I'm assuming there are conventions in ANZLIC that are useful for a metadata consuming application to know. How does an ANCLIC metadata document tell the user that the metadata conforms to that profile?
like all controlled vocabulary used in xml, I'd like to see it implemented as a scoped name with an identifier for the containing vocabulary, an identifier for the concept in the vocabulary, a language-localized label for the concept, and a URL for a definition service or other resources... (interoperability requires a controlled vocabulary of metadata standards....)
steve
John
snip
> Hi All,
Yes.
tell the user
As mentioned, by validation using the ANLZIC Schematron.
I believe a nicer solution would be an official ISO TC 211 endorsed registry of registered profiles. This will allow users to find all approved existing profiles to see if something exists that meets their needs before defining yet another profile. If an existing profile only partially meets their needs then they could extend the existing profile and register that extension at the official ISO TC 211 endorsed registry of profiles.
John
steve
> John
snip
