[GeoNetwork-devel] Incorrect behavior while printing records to PDF
Hello everyone,
Happy New year to all.
I am using Geonetwork 2.6.X branch version of source code, I know it’s quite old. But I would like to know whether following behavior still exist in new version of Geonetwork 2.8.X?
Has any body seen this before and provide me more information about this?
Step 1: Perform search, select 2 records
Step 2: Click on Print to PDF, 2 records are printed to PDF.
Step 3: Now select another 2 records, total number of records now selected are four
Step 4: Click on print to PDF, again only 2 records are selected as in Step 2
Step 5: Now select another 3 records, total number of records now selected are 7
Step 6: Click on print to PDF, again only 2 records are selected as in Step 2
Has anyone seen this behavior before, any idea whether it’s already fixed in any version?
Thanks in advance
Kind Regards
Amol Relkar
Hi Amol
There’re some fixes related to pdf printing, but not exactly the same you report seem: http://trac.osgeo.org/geonetwork/ticket/636 , http://trac.osgeo.org/geonetwork/ticket/646 and http://trac.osgeo.org/geonetwork/ticket/629
I tried with a project using 2.6.x code from old SVN repository (rev 9083) and seem working fine doing your tests, are you trying with latest source code in GitHub?
Also in trunk seem fine for me.
Jose García
On Thu, Jan 3, 2013 at 5:37 AM, Amol Relkar <amol171985@anonymised.com> wrote:
Hello everyone,
Thanks in advance
Kind Regards
Amol Relkar
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only – learn more at:
http://p.sf.net/sfu/learnmore_122712
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hello Garcia,
Thanks for the response.
It turned out to be a network/caching issue in my organization. While accessing geonetwork application I found out that for some reason request to print PDF was not reaching server and it’s showing PDF with same results.
Good day ahead!
Thanks and Regards
Amol Relkar
On Thu, Jan 3, 2013 at 8:46 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Amol
Jose García
Hello everyone,
Thanks in advance
Kind Regards
Amol Relkar
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
