[GeoNetwork-devel] info.json java.lang.NullPointerException
Lately on the 2.8 branch (nightly builds) I started noticing the following
errors. Just wondering if anyone know what could have been committed
recently to cause this problem.
Thank you.
2012-11-30 13:44:22,759 INFO [jeeves.request] - HTML Request (from
192.168.138.1) : /geonetwork/srv/eng/main.home
2012-11-30 13:44:22,759 DEBUG [jeeves.request] - Method : GET
2012-11-30 13:44:22,759 DEBUG [jeeves.request] - Content type : null
2012-11-30 13:44:22,760 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2012-11-30 13:44:22,761 DEBUG [jeeves.request] - Session id is
5fvd5p7f7wd014k5pmculw10u
2012-11-30 13:44:22,762 INFO [jeeves.service] - Dispatching : main.home
2012-11-30 13:44:22,762 DEBUG [jeeves.service] - -> no input parameters
2012-11-30 13:44:22,768 INFO [jeeves.service] - -> dispatching to output
for : main.home
2012-11-30 13:44:22,961 INFO [jeeves.service] - -> transforming with
stylesheet : /tmp/geonetwork/web/geonetwork/xsl/main-page.xsl
2012-11-30 13:44:23,235 INFO [jeeves.service] - -> end transformation
for : main.home
2012-11-30 13:44:23,235 INFO [jeeves.service] - -> output ended for :
main.home
2012-11-30 13:44:23,236 INFO [jeeves.service] - -> dispatch ended for :
main.home
2012-11-30 13:44:26.978:WARN::/geonetwork/pdf/info.json
  at
org.mapfish.print.servlet.MapPrinterServlet.getInfo(MapPrinterServlet.java:257)
  at
org.mapfish.print.servlet.MapPrinterServlet.doGet(MapPrinterServlet.java:87)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:534)
  at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1352)
  at
org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:96)
  at
org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1323)
  at
org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
  at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
  at
org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
  at
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
  at
  at
org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:31)
  at
  at
org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:474)
  at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)
  at
org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:480)
  at
org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
  at
org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:934)
  at
org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:404)
  at
org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:184)
  at
org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:869)
  at
org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
  at
org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:247)
  at
org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:151)
  at
org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
  at org.eclipse.jetty.server.Server.handle(Server.java:346)
  at
org.eclipse.jetty.server.HttpConnection.handleRequest(HttpConnection.java:581)
  at
org.eclipse.jetty.server.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:1040)
  at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:592)
  at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:214)
  at org.eclipse.jetty.server.HttpConnection.handle(HttpConnection.java:411)
  at
org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:526)
  at
org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:41)
  at
org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:528)
  at java.lang.Thread.run(Thread.java:679)
View this message in context: http://osgeo-org.1560.n6.nabble.com/info-json-java-lang-NullPointerException-tp5019963.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
I noticed that as well. There was a recent update of the mapfish snapshot so perhaps there was a change in that project. I will look into this.
Jesse
Thank you.
text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8
2012-11-30 13:44:22,762 DEBUG [jeeves.service] - → no input parameters
2012-11-30 13:44:22,768 INFO [jeeves.service] - → dispatching to output
for : main.home
2012-11-30 13:44:22,961 INFO [jeeves.service] - → transforming with
2012-11-30 13:44:23,235 INFO [jeeves.service] - → end transformation
for : main.home
2012-11-30 13:44:23,235 INFO [jeeves.service] - → output ended for :
main.home
2012-11-30 13:44:23,236 INFO [jeeves.service] - → dispatch ended for :
main.home
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Keep yourself connected to Go Parallel:
TUNE You got it built. Now make it sing. Tune shows you how.
http://goparallel.sourceforge.net
GeoNetwork-devel mailing list
Hi Jesse
I think is related to that, we faced same issue last week for a project, checked with older version of that library and seemed better.
Does exist a stable version of Mapfish? Should be better to reference it instead of snapshot in maven dependencies
Jose García
Thank you.
for : main.home
for : main.home
main.home
main.home
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
I think I can probably cut a mapfish-print release pretty soon. I finally
got it to be a pluggable system. Not 100% but a good step forward. This
means I am a little more comfortable making a new release of it. As soon
as I do that I will cut a release.
I have pushed a fix that should hopefully address this issue. It does locally in any case. I will try to find to cut a mapfish-print release in the following weeks as well.
On Mon, Dec 3, 2012 at 8:49 AM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
I think I can probably cut a mapfish-print release pretty soon. I finally got it to be a pluggable system. Not 100% but a good step forward. This means I am a little more comfortable making a new release of it. As soon as I do that I will cut a release.
Jesse,
Will your fix work on the 2.8 branch as well? I noticed it was only
committed to the master.
View this message in context: http://osgeo-org.1560.n6.nabble.com/info-json-java-lang-NullPointerException-tp5019963p5020352.html
The fix wouldn’t work because of spring version issues. But there is a pre-spring version of mapfish-print that is used by georchestra that we can use for geonetwork. It is a normal version of mapfish-print, nothing special about it excepted it has been released and given a stable version number.
Jesse
On Mon, Dec 3, 2012 at 2:48 PM, ianwallen <ianwallen@anonymised.com.> wrote:
Jesse,
BUILD Helping you discover the best ways to construct your parallel projects.
