Hi Francois, Andrew, et al,
Until recently, I worked on the ISO 19115-1. I don't think that the UML
has changed since then, if so, the changes will be minimal.
There have been changes to the constraints package. The root class,
MD_Constraints, has had several extra attributes added to it that should
meet your requirements. They are:
- constraintApplicationExtent [0..*]: EX_Extent
- graphic: MD_BrowseGraphic [0..*]
- reference: CI_Citation [0..*]
- releasability: MD_Releasability [0..1]
- responsibleParty: CI_Responsibility [0..*]
Of course these are all inherited into the MD_LegalConstraints and
MD_SecurityConstraints classes by the generalisation/specialisation of
the MD_Constraints class.
I think in your case you would use the MD_LegalConstraints class to
define your licences. The elements may look like this:
- use the useLimitation for a statement about the constraint. eg. "A
licence is needed to use or access this resource/metadata".
- use accessConstraints or useConstraints to identify that a licence is
needed for the resource/metadata. IE. choose "license" from a pick list.
- use the reference: CI_Citation [0..*] attribute to link to a licence
agreement. The CI_Citation class will have an onlineLink so you can link
to a web page etc. You can also identify the licence name eg. GPL,
responsibleParty eg. Apache, etc. etc.
- use the constraintApplicationExtent [0..*]: EX_Extent to identify any
time or spatial extents limitations on the licence agreement for that
resource/metadata. eg. "Licence is for one year." "Licence applies to
France."
- use the graphic: MD_BrowseGraphic [0..*] to show a Creative Commons
icon or something similar. There will be an onlineLink in the
MD_BrowseGraphic class so you can link to a online image etc.
- use the releasability: MD_Releasability [0..1] to identify to whom the
resource/metadata can be released. eg. "Only available to French
people."
- use the responsibleParty: CI_Responsibility [0..*] attribute to
identify who is responsible for the constraints of the
resource/metadata. eg. "Constraint applied by Francois."
However, until ISO 19115-1 is published then I tend to agree with Andrew
that it can be lumped into multiple useLimitation statements.
I hope that this helps.
John Hockaday.
P.S. I have assumed that you are French for the above examples. Please
forgive me if that assumption is wrong, but you'll still get the
idea. ;--)
JH
On Mon, 2012-08-27 at 08:29 +0200, Francois Prunayre wrote:
Hi Andrew,
2012/8/27 andrew walsh <awalsh@anonymised.com>:
> Hi Francois,
> Isn't the "license" a "use limitation" so could it just be stored in
> say
> gmd:resourceConstraints/gmd:MD_LegalConstraints/gmd:useLimitation/gco:CharacterString
I've seen both elements used but useLimitation is probably better.
Anyone know if the next version of ISO19115 will modify the constraint
element ?
Thanks for your input.
Francois
> or
> gmd:resourceConstraints/gmd:MD_LegalConstraints/gmd:useLimitation/gmx:Anchor
> Or maybe you are already using the gmd:useLimitation/gco:CharacterString and
> you need
> to put extra info. gmd:otherConstraints/gco:CharacterString ?
> HTH,
> Andrew
> ----- Original Message ----- From: "Francois Prunayre"
> <fx.prunayre@anonymised.com>
> To: <geonetwork-devel@lists.sourceforge.net>
> Sent: Saturday, August 25, 2012 2:23 AM
> Subject: [GeoNetwork-devel] Information about the license in a
> metadatarecord
>> Hello all,
>> We have the need to easily set the license information in a metadata
>> record. There are different options and ways to set information about
>> license, so If you've idea and comments on the following do not
>> hesitate.
>> Where to store the information about the license ?
>> In ISO19139, maybe gmd:otherConstraints is a good place. Some ISO
>> profiles add extra elements (like MCP, mcp:licenseLink,
>> mcp:licenseName, ... [1]).
>> How to easily populate the field ?
>> 1) use suggestion to provide a select box next to the field (like for
>> denominator). One issue here is that we don't have link to the
>> license.
>> 2) use a gmx:Anchor instead of gco:CharacterString to have a link to the
>> license
>> <gmd:otherConstraints>
>> <gmx:Anchor
>> xlink:href="http://opendatacommons.org/licenses/odbl/">ODBL</gmx:Anchor>
>> </gmd:otherConstraints>
>> 3) use a directory of license (subtemplates) and provide selection
>> like for contact directory.
>> 4) use a register (iso19135) to manage a codelist of licenses and use
>> it to populate the information.
>> 5) more advanced wizard ...
>> 6) ...
>> If anyone is interested in the topic, we could try to discuss it on
>> next tuesday IRC and try to find a common approach ?
>> Thanks for your inputs.
>> Francois
>> [1]
>> https://github.com/geonetwork/schema-plugins/blob/master/iso19139.mcp-1.4/set-datacommons.xsl
>> Live Security Virtual Conference
>> Exclusive live event will cover all the ways today's security and
>> threat landscape has changed and how IT managers can respond. Discussions
>> will include endpoint security, mobile security and the latest in malware
>> threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
>> _______________________________________________
>> GeoNetwork-devel mailing list
>> GeoNetwork-devel@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
>> GeoNetwork OpenSource is maintained at
>> http://sourceforge.net/projects/geonetwork
