It would like to know as I can install the Geonetwork as a service of the Windows? Already I tried to follow the suggestion of the aid for installation of the Geonetwork with the Tomcat, but when I go to test, the map is loading, but it does not load. I followed all the installation steps. What necessary to make in the InterMap it to start to function with the Tomcat?
Marcelo G. Santana
marcelo@anonymised.com
Topos Informática do Brasil Ltda.
Could you check that the InterMap is using the correct port number, which should be the same as the port of the GeoNetwork ?
See
/bin/jetty.xml for the GeoNetwork’s port number;
and
/web/intermap/WEB-INF/mapServers.xml for the InterMap’s configuration, in particular the section
[http://localhost:80/geoserver/wms](http://localhost:80/geoserver/wms)
The localhost’s port number should be the same as the GeoNetwork’s from jetty.xml.
Regards
Heikki Doeleman
On Mon, Jul 14, 2008 at 10:18 AM, Marcelo G. Santana <marcelo.g.santana@anonymised.com> wrote:
Marcelo G. Santana
Sponsored by: SourceForge.net Community Choice Awards: VOTE NOW!
Studies have shown that voting for your favorite open source project,
along with a healthy diet, reduces your potential for chronic lameness
and boredom. Vote Now at http://www.sourceforge.net/community/cca08
GeoNetwork-devel mailing list
Hi Heikki,
Much thankful by its aid, but not yet I obtained to solve my problem.
I verified the files “Jetty.xml” and “MapServers.xml”, and I did not obtain to find the problem. I did not find in the file “MapServers.xml” the code that you sent, therefore I am transcribing the part of the code of my archive more similar to its:
My computer run the Windows XP, and I made the installation in the following way:
- I installed " jre-1_5_0_07-windows-i586-p.exe"
- I installed the complete version of " apache-tomcat-5.5.26.exe" , and I configured the Tomcat for port 8080.
- I installed the complete version of " geonetwork-install-2.1.0.exe"
- I initiated " GAST" e I configured:
Configuration/Jetty: (default)
→ Servelet = geonetwork
→ Port = 8080
Configuration/DBMS: (modified to…)
→ DBMS = PostgreSQL
→ Server = MyServerPostgreSQL
→ Port = 5432
→ Database = geonetwork
→ Username = MyUsername
→ Password = MyPassword
Menu → Options/Config: (default)
→ Server = Embedded
→ Acount = No Authentication
- In the file “C:\tomcat\conf\server.xml” I made an modification:
Before tag I inserted the code:
After to restart tomcat, the Geonetwork appears in the browser, but the map is loading and it does not finish to load.
If somebody will be able to help me, will be grateful.
They forgive me for the incorrect English.
Marcelo G. Santana
2008/7/14 heikki <tropicano@anonymised.com>:
See
and
Regards
Heikki Doeleman
Marcelo G. Santana
