[GeoNetwork-devel] integrate the geonetwork in other application?
Hi:
I have another java swing application and I want to use the geonetwork as a CSW instance.
For example in my application I have to register some ows urls(http://www.example.org:8080/wcs) in a config file,now I want to register them with a CSW insance ,so I try to use geonetwork.
Here I have two problems:
  1. Can I integrate the geonetwork into my application?
  2. If the answer of the above is yes,so how to do? That’s to say how to install the geonetwork quietly when I run the application
    Anyone can give some advise?
hello Maven,
yes, it should be possible.
The way to do it should be to include geonetwork.jar in your classpath and treat it like you would any other library. There are probably some dependencies with other jars that normally are in /web/geonetwork/WEB-INF/lib, just copy those as well into your application’s classpath.
Kind regards
Heikki Doeleman
On Tue, Oct 27, 2009 at 8:21 AM, maven apache <apachemaven0@anonymised.com> wrote:
Hi:
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
GeoNetwork-devel mailing list
2009/10/27 heikki <tropicano@anonymised.com>
hello Maven,
Thanks for your reply.
It seems to be easy. But I am afraid how to register ,query and use the ows(ogc web service) urls.
Since with the independent geonetwork one can do the above operation(register query) through a web manner,I am not sure how to do it in my application.
Kind regards
Heikki Doeleman
Hi:
yes, I think it is not quite THAT easy as I sketched :slight_smile:
I think you’ll might have some difficulty also in setting up things like the Jeeves application context, which normally is set up when the GN web app starts. Although it should be possible to do it from your app too, I think.
As for the operations accessible through the web : I think you could do those operations by “forwarding” them from your own app to GeoNetwork using a programmatic HTTP request from your Java code. It may not be ideal but that may be the easiest way to go forward now.
In future, we hope to have GeoNetwork more modularized, and so make it more easy to use its component parts separately as a library. For now I think you’ll need some fiddling around as sketched to get it to work.
Kind regards
Heikki Doeleman
On Tue, Oct 27, 2009 at 8:05 PM, maven apache <apachemaven0@anonymised.com> wrote:
hello Maven,
Kind regards
Heikki Doeleman
Hi:
Kind regards
Thank you very much for your detailed advise!!
So I have a idea but I am not sure it is right or not:
I copy all the files under the GN-roots/* to a directory in my application,so when I run my application I also call a script {maybe :java.lang.Runtime.exec(“Myapplication/GN/bin/start-geonetwork.bat”)} to start the GN. Also I can add some interface in my application to interact with the GN(CSW).
I wonder the idea is feasible or not?
Heikki Doeleman
hello Maven,
Kind regards
Heikki Doeleman
Hi:
hi Maven,
I think your approach should work, although it sounds a bit unconventional, you’re not really using GN as a library like that but just starting it as a separate application.
In the Bolsena meeting this spring Just van den Broecke has started to write a Junit extension “JeevesTestCase” which I think should contain code to set up the Jeeves application context without actually starting the GeoNetwork web application. It’s not yet committed to trunk, but I’ve asked him to send me the code, if it’s useful I’ll pass it on to you here.
Kind regards
Heikki Doeleman
On Tue, Oct 27, 2009 at 11:09 PM, maven apache <apachemaven0@anonymised.com> wrote:
Kind regards
Heikki Doeleman
hello Maven,
Kind regards
Heikki Doeleman
Hi:
Yes, in order to do unit-testing I needed a way to invoke GN/Jeeves as a library. This work was initially done in the geocat.ch branch but in Bolsena (june 2009) I started porting this work into trunk. The test framework still needs finalization to allow both local and remote invocation. I just checked-in all modified files. All relevant files can be found here:
- test framework
http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/trunk/src/org/fao/geonet/test
- sample tests
http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/trunk/test
Back to the question: the class to run Jeeves as a library ("local") without a servlet engine and dispatch GN requests, is within Jeeves itself:
http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/trunk/jeeves/src/jeeves/server/local
See LocalJeevesMediator.java in the test framework how GN is started locally. The "trick" is to provide all the proper paths to configs. Hope this helps.
best,
heikki wrote:
hi Maven,
I think your approach should work, although it sounds a bit unconventional, you're not really using GN as a library like that but just starting it as a separate application.
In the Bolsena meeting this spring Just van den Broecke has started to write a Junit extension "JeevesTestCase" which I think should contain code to set up the Jeeves application context without actually starting the GeoNetwork web application. It's not yet committed to trunk, but I've asked him to send me the code, if it's useful I'll pass it on to you here.
Kind regards
Heikki Doeleman
On Tue, Oct 27, 2009 at 11:09 PM, maven apache <apachemaven0@anonymised.com <mailto:apachemaven0@anonymised.com>> wrote:
    2009/10/27 heikki <tropicano@anonymised.com <mailto:tropicano@anonymised.com>>
        I think you'll might have some difficulty also in setting up
        could do those operations by "forwarding" them from your own app
        forward now.
        library. For now I think you'll need some fiddling around as
        Kind regards
    :java.lang.Runtime.exec("Myapplication/GN/bin/start-geonetwork.bat")}
        Heikki Doeleman
                hello Maven,
                <geonetwork-root>/web/geonetwork/WEB-INF/lib, just copy
                those as well into your application's classpath.
            Thanks for your reply. It seems to be easy. But I am afraid how to register ,query
                Kind regards
                Heikki Doeleman
                wrote:
                    Hi:
                    1) Can I integrate the geonetwork into my application?
                    2) If the answer of the above is yes,so how to do?
                    That's to say how to install the geonetwork quietly
                    2009. Register now!
                    <mailto:GeoNetwork-devel@lists.sourceforge.net>
            in SF, CA
            Jumpstart your
            market and stay
            Register now!
    stay
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9 - 12, 2009. Register now!
2009/10/28 heikki <tropicano@anonymised.com>
hi Maven,
Thanks for your advise,I think I may use the first way(start the geonetwork as a separate app) since this manner would be easier. :slight_smile:
Also thanks for Just van den Broecke’s codes!
Kind regards
Heikki Doeleman
Kind regards
Heikki Doeleman
hello Maven,
Kind regards
Heikki Doeleman
Hi:
