jmrliz
September 18, 2008, 4:25pm
1
Hello.
I wanted to know if there is any way of using GeoNetwork services (for
accesing remote geo-data, for instance) from within a GIS client; in this
case, MapBuilder (Javascript/Java).
Thanks.
Jesús
View this message in context: http://www.nabble.com/Integrating-GeoNetwork-into-MapBuilder-tp19556750p19556750.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hello,
You have such plugin in Cartoweb (not sure it's available in core I
guess).
It's also planned to add such widgets in the MapFish project in order to
use OpenLayers instead of Intermap for the catalogue search interface:
* http://trac.osgeo.org/geonetwork/wiki/ReplacingIntermap
* http://trac.mapfish.org/trac/mapfish/wiki/Proposals/Catalogue
in this
Not sure about MapBuilder, but you could easily query GeoNetwork
catalogue using xml.search, rss.search services and then display
results.
HTH.
Francois
