[GeoNetwork-devel] Intermap Google Maps
Hello everyone
I’d like to add Google Map to my layers (as a background).
Has anyone did that before?
Best regards.
Ludba
Get the name you’ve always wanted ! @ymail.com or @rocketmail.com.
Hi Ludba,
Abel Ludba wrote:
I'd like to add Google Map to my layers (as a background).
Using Intermap, it will be quite difficult I guess.
You should probably investigate in OpenLayers integration made in some
sanboxes, you could have a look to :
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/sandbox/geocat.ch
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/sandbox/GeoSource
HTH.
Francois
Best regards.
Ludba
Get the name you've always wanted <http://ca.promos.yahoo.com/jacko/&gt;\!
*@ymail.com *or *@rocketmail.com*.
GeoNetwork-devel mailing list
And you have to consider the license restrictions when using the Google layer.
Ciao,
Jeroen
On Mar 11, 2009, at 11:58 AM, Francois-Xavier Prunayre wrote:
Hi Ludba,
HTH.
Francois
Best regards.
Ludba
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
