[GeoNetwork-devel] is _xlink field in index used ?
Hi all, anyone know if _xlink field in the index is used ?
https://github.com/geonetwork/core-geonetwork/blob/develop/core/src/main/java/org/fao/geonet/kernel/DataManager.java#L507
When too many xlinks are defined in the record, indexing fails with
Error: Document contains at least one immense term in field=“_xlink” (whose UTF8 encoding is longer than the max length 32766), all of which were skipped. Please correct the analyzer to not produce such terms. The prefix of the first immense term is: ‘[32, 104, 116, 116, 112, 58, 47, 47, 99, 97, 116, 97, 108, 111, 103, 117, 101, 46, 102, 111, 114, 109, 97, 116, 105, 111, 110, 46, 115, 105]…’, original message: bytes can be at most 32766 in length; got 141611
It may be useful to check which records use a subtemplate. But I can’t find something like this.
Thanks.
Francois
Hi Francois
I’ve never used that field.
What stores that field? The ids of the the subtemplates used?
Jose García
On Wed, Oct 28, 2015 at 5:11 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Thanks.
Francois
GeoNetwork-devel mailing list
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
2015-10-28 17:13 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
I've never used that field.
The list of xlink of the record. So it could be quite long URLs and at some
point, the max Lucene field length is reached. Maybe we should catch this
exception, remove the field from the doc, and add it to the index with a
indexingError.
Francois
Jose García
Error: Document contains at least one immense term in field="_xlink"
prefix of the first immense term is: '[32, 104, 116, 116, 112, 58, 47, 47,
105, 111, 110, 46, 115, 105]...', original message: bytes can be at most
It may be useful to check which records use a subtemplate. But I can't
Thanks.
Francois
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Hi Francois
But what mean the numbers? Are the identifiers used by the metadata editor for the elements? Just trying to understand the usage of that field.
Jose García
On Wed, Oct 28, 2015 at 5:16 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi Francois
The list of xlink of the record. So it could be quite long URLs and at some point, the max Lucene field length is reached. Maybe we should catch this exception, remove the field from the doc, and add it to the index with a indexingError.
Francois
Jose García
Thanks.
Francois
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
