Hi
When validating ISO19110 metadata in trunk, there errors like:
src-resolve: Cannot resolve the name ‘gmd:AbstractDQ_PositionalAccuracy’ to a(n) ‘element declaration’ component. (Element: gfc:FC_FeatureCatalogue with parent element: Unknown
Identified that the problem happens before validating the metadata, when GeoNetwork loads the schema files for ISO19110, seem the includes in the file xml/schemas/iso19110/schema.xsd are not ok at all.
I did this change:
<xs:import namespace=“http://www.isotc211.org/2005/gmd” schemaLocation=“…/iso19139/schema/gmd/metadataEntity.xsd”/>
<xs:import namespace=“http://www.isotc211.org/2005/gco” schemaLocation=“…/iso19139/schema/gco/basicTypes.xsd”/>
Instead of:
<xs:import namespace=“http://www.isotc211.org/2005/gmd” schemaLocation=“…/iso19139/schema/gmd/citation.xsd”/>
<xs:import namespace=“http://www.isotc211.org/2005/gmx” schemaLocation=“…/iso19139/schema/gmx/gmx.xsd”/>
and seem working ok.
The main concern is that this file seem is created automatically (at least from comments in header), so:
Do you think is ok to commit this version changed manually?
Or should be another updated version of the file that maybe fixes this? In this case, anyone knows from where was obtained this file?
Thanks and regards,
Jose García
