Hi Francois,
I believe that the XPATH you state below is the correct location "to
make references to datasets used to create the another one". I have
partially used this in a mock-up metadata record but never in a real
metadata record instance.
I hope that this helps.
John
P.S. In the revision of ISO 19115-1 I believe there is an "onlineLink"
element in the "source"
-----Original Message-----
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: Tuesday, September 27, 2011 2:33 AM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] ISO19115 DQ Lineage / ref to
source datasets
Dear all,
I would like to make references to datasets used to create another one
in a metadata record. Looking to the Data Quality section of ISO19115,
it looks like we could use the source element in Linage (ie
gmd:LI_Lineage/gmd:processStep/gmd:LI_ProcessStep/gmd:source). Anyone
is using it ? and/or using the uuiref attribute to point to another
metadata record (like we do in srv:operatesOn element for linking
metadata on services and datasets ) ?
Thanks for your inputs.
Cheers.
Francois
All the data continuously generated in your IT infrastructure
contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data
and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2dcopy1
GeoNetwork-devel mailing list
The information contained in this e-mail, and any attachments to it,
is intended for the use of the addressee and is confidential. If you
are not the intended recipient you must not use, disclose, read,
forward, copy or retain any of the information. If you received this
e-mail in error, please delete it and notify the sender by return
e-mail or telephone.
The Commonwealth does not warrant that any attachments are free
from viruses or any other defects. You assume all liability for any
loss, damage or other consequences which may arise from opening
or using the attachments.
The security of emails transmitted in an unencrypted environment
cannot be guaranteed. By forwarding or replying to this email, you
acknowledge and accept these risks.
