[GeoNetwork-devel] ISO19115 or ISO19139 Upgrade
Hi All,
            I am trying to add an extension to the ISO 19139 to Geonetwork
but I have realized that the current support within Geonetwork is 5 years
old and does not reflect the actual specification. I am about to upgrade it
myself but thought I would see if anyone is or has done this before. If so,
how close are you to a finished product? Will you be releasing it back into
the open source code?
            As for the actual upgrade, it seems to me that all I will need
to do is update the XML Schema and alter any XSL files so that they refer to
the new names for elements (it seems the structure is still very similar, if
not the same). Once this is done, I just need to add the extension fields to
the forms to support the extended version. However this all seems too easy.
If it was this easy surely someone would have done it by now. Please tell me
that I am not missing something here.
Steven Smith <steven.smith@anonymised.com>
Software Developer / Analyst
Geometry Pty Ltd
Telephone
03 6223 1999
Facsimile
03 6223 1988
Web
www.geometryit.com
<file:///C:\Documents%20and%20Settings\ssmith.GEOMETRY\Application%20Data\Mi
crosoft\Signatures\www.geometryit.com>
Address
31 Salamanca Square, Battery Point, TAS 7004, Australia
Postal
PO Box 844, Sandy Bay, TAS 7006, Australia
Building Intelligent Business through the Power of Spatial
Hi Steven,
On Oct 4, 2006, at 5:02 AM, Steven Smith wrote:
All the required code is already in the CVS and we are about to make a first alpha release. This includes a migration procedure to move from the old 19115 format to the 19139 based one. It also includes the OGC-CSW 2.0.1 implementation of catalogs based on the ISO application profile.
We have purposely not done intermediate updates to the standard over the last years since this would take a lot of time without mayor benefits and more complex upgrade procedures. (Also, the 19139 standard is close to final for over two years now and we have been waiting for it for a long time preventing us from implementing it at an earlier stage).
Have a close look at the code in the CVS and build the latest version if you want to. That can save you a lot of time of which you may spent some in helping us getting the release well tested :wink:
Greetings,
Jeroen
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys – and earn cash
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.coms.sourceforge.net
Thanks Jeroen, I will get the latest and do some testing. Makes perfect
sense why you have waited till now.
Geometry Pty Ltd
Telephone
03 6223 1999
Facsimile
03 6223 1988
Web
www.geometryit.com
Address
Postal
  _____
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Wednesday, 4 October 2006 7:22 PM
To: Steven Smith
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] ISO19115 or ISO19139 Upgrade
Hi Steven,
Hi All,
I am trying to add an extension to the ISO 19139 to Geonetwork but I have
realized that the current support within Geonetwork is 5 years old and does
not reflect the actual specification. I am about to upgrade it myself but
thought I would see if anyone is or has done this before. If so, how close
are you to a finished product? Will you be releasing it back into the open
source code?
As for the actual upgrade, it seems to me that all I will need to do is
update the XML Schema and alter any XSL files so that they refer to the new
names for elements (it seems the structure is still very similar, if not the
same). Once this is done, I just need to add the extension fields to the
forms to support the extended version. However this all seems too easy. If
Greetings,
Jeroen
Geometry Pty Ltd
Telephone
03 6223 1999
Facsimile
03 6223 1988
Web
www.geometryit.com
Address
Postal
opinions on IT & business topics through brief surveys -- and earn cash
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;
