[GeoNetwork-devel] iso19139 metadata profile - validation
Hi Martin, Hi all
following your email to Ursula (Re: display of new metadata schema, new metadata profile / 2006-07-25) on your personal metadata profile “iso19115-preagro” I’ve tried to do something similar and it works; as you wrote do you still plan to provide an howto for adding iso19139 compliant docs?
I have my own metadata schema (iso19139 compliant) which imports/includes local copy of the iso19139 XSDs: I’d need to integrate this profile together with the local iso files in geonetwork and validate instance docs against it (by adding them through the XMLInsert form)… But still not sure on how to do it.
Which would be the best solution? Where to store the local iso files? Which files should I modify? Could you/someone help?
It seems the creation and use of iso19139 metadata profiles are important issues for several geonetwork users…
Thanks a lot in advance for any help!!
Veronica
