[GeoNetwork-devel] Issues with recurse when harvesting from a Web Dav
When we were running GeoNetwork 2.2, I had no problems with recurse when
harvesting from a web dav. But now we have upgraded to GeoNetwork 2.4.2 and
when I am trying to harvest the same files from the same web dav, I get no
errors. It just says it has run by showing the green check mark, but when
you hover over the green check mark it says Zero found, Zero harvested, etc,
etc (it's all zeros)
Has anyone else seen this? Does anyone know if this is a bug or how to fix
this?
View this message in context: http://n2.nabble.com/Issues-with-recurse-when-harvesting-from-a-Web-Dav-tp4151664p4151664.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
