[GeoNetwork-devel] java.lang.OutOfMemoryError on Geonetwork 2.4.3
Dear list,
I suspect there’s a memory leak problem on geonetwork 2.4.3: I did the upgrade from 2.2.0 and I keep getting java.lang.OutOfMemoryError some time after tomcat startup.
My VM configuration is:
-Xms48m -Xmx1500m -XX:MaxPermSize=256m -XX:PermSize=128m
(I increased -Xmx to 1500m see if the new version was just RAM demanding).
I also fixed some problems in Lucene indexing, should I checkin? On branches/2.4.3?
Thanks for your help
Stefano
Hi
I dont know if this is related to your issue
I was getting a Tomcat died on "java.lang.OutOfMemoryError: requested
2147483664 bytes for Chunk. Out of swap space?" error message last week
when running 2.4.3.
But this was just after I upgraded my jvm on linux. There appears to be a
bug in the hotspot compilation in latest sun jvm. .
I added -Xint (Operate in interpreted-only mode) to startup params. to
confirm that this bug was affecting my setup.
No more out of memory problems as soon as I added -Xint.
I then had to downgrade to my previous version of the jvm.
Murray
View this message in context: http://osgeo-org.1803224.n2.nabble.com/java-lang-OutOfMemoryError-on-Geonetwork-2-4-3-tp5203547p5203637.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Stefano
In 2.4.3 is included a fix for saxon and java 1.6 that produced an OutOfMemory exception:
http://osgeo-org.1803224.n2.nabble.com/SF-net-SVN-geonetwork-5999-branches-2-4-x-bin-td4937268.html#a4937268
The fix commited is for jetty, but is similar for tomcat. Please check next url to verify for tomcat statup script is fixed:
http://osgeo-org.1803224.n2.nabble.com/Re-GeoNetwork-users-Java-updates-td4935064.html
If not using java 1.6 then should be caused by other new problem. In that case is an option for you to use YourKit profiler to make a memory profiling session so can analyze the results? Other option is if you can post the geonetwork.log file to check, but please verify first if is caused by java 1.6 and saxon issue.
Jose Garcia
On Mon, Jun 21, 2010 at 11:27 AM, Stefano Giaccio <Stefano.Giaccio@anonymised.com> wrote:
Dear list,
Stefano
ThinkGeek and WIRED’s GeekDad team up for the Ultimate
GeekDad Father’s Day Giveaway. ONE MASSIVE PRIZE to the
lucky parental unit. See the prize list and enter to win:
http://p.sf.net/sfu/thinkgeek-promo
GeoNetwork-devel mailing list
Hi Murray,
Add the following to your JAVA_OPTS env variable and restart tomcat - then only the method (from Saxon XSLT) that is causing the problem will be run in interpreted mode:
-XX:CompileCommand=exclude,net/sf/saxon/event/ReceivingContentHandler.startElement
Simon
________________________________________
Sent: Monday, 21 June 2010 7:51 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] java.lang.OutOfMemoryError on Geonetwork 2.4.3
Hi
when running 2.4.3.
Murray
ThinkGeek and WIRED's GeekDad team up for the Ultimate
GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
A better solution appears to be patch the method in saxon (9.1.0.8) to remove some code required for jdk1.4 and replace it with code that works only with jdk1.5 (from 9.2HE) - this is fine for us as GN assumes 1.5 as a minimum. I'm testing this at the moment. If it proves ok then we should be able to do away with this exclusion.
Simon
Simon.Pigot@anonymised.com wrote:
Hi Murray,
Simon
Hi
when running 2.4.3.
Murray
ThinkGeek and WIRED's GeekDad team up for the Ultimate GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the lucky parental unit. See the prize list and enter to win: http://p.sf.net/sfu/thinkgeek-promo
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Thanks for your help, I'll try with the solutions that you suggested (I just got the messages as my mail server promptly stopped working yesterday) and let you know how it goes.
Stefano
Simon
Hi Murray,
Simon
Hi
when running 2.4.3.
Murray
