[GeoNetwork-devel] jQuery?
I’m looking at making a small change for our purposes so that the tooltips (when editing metadata) are draggable. Then I could put much more text in them and not worry about them covering over the editing elements.
I was expecting to just use the jQuery ui-draggable class, as I thought we were using jQuery because I used it (or something very very like it) in the recent change to the validation results filter.
I can’t see where/if it is loaded. $(‘document’) returns null when editing. Am I missing something?!
Thanks in advance,
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Hi Justin,
On Mon, Oct 4, 2010 at 2:21 PM, Justin Rowles (C) <Justin.Rowles@anonymised.com> wrote:
We are using ExtJS in GeoNetwork and we do not plan AFAIK to use jQuery also in the UI.
I would say that the use of $(id) in javascript does not refer to the jQuery library but more to the prototype one but I’m not very confident with jQuery.
My 2 cts,
Mathieu
