[GeoNetwork-devel] Latest 2.0.2 source code
Hi list, I would like to get the latest 2.0.2 source code. Should I use the one on the CD (burned last april) or use the CVS ?
In the CVS, I’m torned between Branches V2_0_3 and Versions V2_0_2 … :slight_smile: Which one should I use ?
Thanks for your help.
Francois
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n’a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et privés.Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and private. Any total or partial publication, use or distribution must be authorized.
Hi Francois,
the latest source code is on CVS in the V2_0_FIX2 branch. There are only
a couple of fixes. Maybe we will add some other fixes and release geonetwork
2.0.3. Here is the current list of fixes (as are in docs/changes.txt):
- Fixed bug with user list: if the user is an Administrator but with id other
  than 1 only a subset of the groups where shown
- Fixed validation bug when adding a new metadata
- Fixed bug with thumbnails stylesheet: now the 'back' button is correctly
  shown
In the CVS, I'm torned between Branches V2_0_3 and Versions V2_0_2 .... :slight_smile:
Francois
Hi Luis,
I have fixed it right now, together with other fixes:
- Fixed "Services is not a subcontext" exception with Z39.50
- Fixed problem with IPv6 protocol: geonetwork was unable to handle the
  0:0:0:0:0:0:0:1 local address.
- Fixed a security hole: using sql injection was possible to login into geonetwork
Hi Andrea,
    it's already fixed the bug that makes unusable geonetwork from a
remote client using z39.50? if not ... when?
    thanks in advance
       Luis
Andrea Carboni wrote:
>Hi Francois,
> shown
>Cheers,
>Andrea
>>Francois
>Take Surveys. Earn Cash. Influence the Future of IT
>Join SourceForge.net's Techsay panel and you'll get the chance to share your
>opinions on IT & business topics through brief surveys -- and earn cash
>http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
>_______________________________________________
>GeoNetwork-devel mailing list
>GeoNetwork-devel@lists.sourceforge.net
>https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
>GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
