[GeoNetwork-devel] LDAP authentication and Active Directory
Having a some issues using the LDAP authentication with Active Directory. I think it’s due to case sensitivity, as it appears even though I configure with case, the logs are showing lower case versions of those configuration parameters.
Has anyone have the LDAP authentication working with Active Directory where your DN’s have upper case characters?
Kevin
The information contained within this transmission is for the use of the intended recipient only and may contain confidential and/or legally privileged material and/or material the subject of copyright and/or personal information and/or sensitive information that is subject to the Privacy Act 1988. Any review, re-transmission, disclosure, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you have received this email in error please notify the AIMS Privacy Officer on (07) 4753 4444 and delete all copies of this transmission together with any attachments.
