Is it possible to authenticate a geonetwork instance using LDAP or similar?
Where can I find relevant documentation?
Regards
Greg Coleman
Australian Institute of Marine Science.
The information contained in this communication is for the use of the
individual or entity to whom it is addressed, and may contain
information which is the subject of legal privilege and/or copyright.
If you have received this communication in error, please notify the
sender by return E-Mail and delete the transmission, together with any
attachments, from your system. Thank you.
Hi Greg,
currently you cannot use LDAP or any other authentication mechanism
other than the geonetwork's one. Anyway, LDAP authentication has
been planned (I cannot say for when).
similar?
Regards
Greg Coleman
Hi Andrea,
I wrote some code to do LDAP authentication and it seems to work
OK for what I want although not very flexible.
See attached.
Greg.
-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] On Behalf Of
Andrea Carboni
Sent: Monday, 23 October 2006 20:34 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] LDAP authentication
Hi Greg,
similar?
Regards
Greg Coleman
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-devel mailing list
(attachments)
AimsLogin.java (5.29 KB)
LDAPLoginModule.java (11.5 KB)
Thanks Greg,
I will give a look. Our idea was to use the LDAP facilities inside Java 1.5.
What did you use?
Hi Andrea,
See attached.
Greg.
Andrea Carboni
Hi Greg,
> similar?
> Regards
> Greg Coleman
security?
easier
Geronimo
