[GeoNetwork-devel] Liisting groups a user is a member of
Hello,
If there an easy way to list groups a user is a member of via XML?
I had thought that this was what xml.usergroups.list was for but the default permissions stop a normal user from using it.
I have changed this and also changed UserGroups.java so that if you don’t provide an id (with a blank request) then your own id is used (diff attached if anyone is interested, it was trivial).
This works fine and seems to make sense, but I am wondering if there is another standard interface I should be using.
James Sewell
Solutions Architect
LISAsoft
(attachments)
userGroupPatch (700 Bytes)
Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
Level 9, 601 Bourke St, Melbourne Vic 3000
http://www.lisasoft.com
