Hi Shawn,
On Jan 12, 2007, at 12:27 AM, Hsiang Yun Chen wrote:
This may be a stupid question, but please bear with me.
Don't think its stupid to ask questions!
If the CSW interface on the catalog server can only be accessed by CSW clients, how does two catalog communicate with each other? As my colleague claimed(not knowing if it is correct or not), data can shared among catalog servers. I am curious about what does that really means.
There's a multitude of protocols for catalogs to communicate:
- CSW 2 is the new kid on the block. we implement CSW 2.0 based on the ISO application profile (content) using the HTTP and SOAP bindings. Harvesting is not part of the current implementation, although I foresee this to happen in the future.
But than there are other existing standards using different binding protocols.
- GeoNetwork implements the OGC CAT 1.0 standard using the so-called Z39.50 binding protocol since the project started. This is often referred to as Z39.50 or ISO 23950. Harvesting through this protocol has not been implemented.
- It also implements a custom protocol that allows harvesting (caching) from another GeoNetwork catalog. This is available in GN 2.0 and is further improved in version 2.1 with a GUI administration interface and with a transfer of e.g. thumbnails, privileges and logo's.
Than there is the OAI interface, something that allows Google for instance to index a catalog and can also be used for harvesting. This is also planned to be added to the catalog, although I'm waiting for a funding hitch to be resolved
OK, hope that helps a bit.
Ciao,
Jeroen
Thanks for the help.
Best regards.
Shawn
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Thu 11/01/2007 11:03 PM
To: Hsiang Yun Chen
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Link Non-GeoNetwork Server Using CWS?
Hi Shawn,
Sorry for the late response.
I'm not very clear on what you try to achieve so answering is a bit
difficult. At this point GeoNetwork v2.1 alpha has a CSW interface on
the catalog (as a server, so CSW clients can interact with it). There
is no functionality in GeoNetwork to connect from the server to
another catalog through the CSW interface (which is what you want to
do if I understand the first part of your question!?).
The WCS (Web Coverage Service) is totally unrelated to CSW (Catalog
Services for the Web) so it would not be an alternative from my
understanding.
CIao,
Jeroen
On Jan 4, 2007, at 1:25 PM, Shawn Chen wrote:
Hi, List,
I am new in the field and trying to link UniData THREDDS catalog
server to GeoNetwork SDI. Is it possible to make the link supposed
that THREDDS with CWS interface?
Or, could it be done by WCS interface? Is WCS for map portrayal
service only?
Any comments?
Most appreciated!!
Best regards.
Shawn
Join SourceForge.net's Techsay panel and you'll get the chance to
share your
opinions on IT & business topics through brief surveys - and earn cash
http://www.techsay.com/default.php?
page=join.php&p=sourceforge&CID=DEVDEV
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
