Hi !
I've been working hard to get something to work using the Ext library.
I needed to put some vertical text and this is not easy in html/css. So I am
using an image instead (see screenshot below)
http://osgeo-org.1803224.n2.nabble.com/file/n6006639/Vertical_Search_Panel.jpg
But now I have trouble for the localisation.
How could I get the system to access a different image in function of the
language ? I see this is done in some places of GN (e.g., nopreview
thumbnail). But I can't find the place where it is called from.
My image is called from
geonetwork\web\geonetwork\scripts\ext\resources\css\ext-all.css
Thanks in advance for a reply !
Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Localisation-Mecanism-to-access-images-containing-text-tp6006639p6006639.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
