[GeoNetwork-devel] Map Viewer Image
I just finished installing GN 2.1 with no apparent problems. However, there
is no image in the overview map in the upper left of main page. When I
click on the 'Open Map Viewer' link below where the map should be, the map
image is also missing.
I am able to add a WMS to the Intermap view by clicking on the green "Add
more layers" icon below the map. That image then shows up in the Map Viewer
and in the overview map.
Is there supposed to be a default map showing up in a fresh installation and
where/how do I set up a default map image?
Thanks, Bob
View this message in context: http://www.nabble.com/Map-Viewer-Image-tf4509887s18419.html#a12862230
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hi Bob,
Check if the default map layers configured in ../web/intermap/WEB-INF/mapServers.xml are pointing to valid map services. the default set of layers is configured in that file.
Ciao,
Jeroen
On Sep 24, 2007, at 6:12 PM, Bob Nutsch wrote:
Thanks, Bob
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-devel mailing list
