Hi All,
Same problem as well, with tomcat 5.5.23 and I have not changed configured ports from defaults. Tomcat is running on default 8080 which should match default config. Here is the exception trace. Is this what others are seeing in regard to this issue?
I'm not able to locate the JAR file that contains this class.
772603 [SEVERE] org.vfny.geoserver.servlets.AbstractService - Service exception
occurred
org.vfny.geoserver.wms.WmsException: Provider de.fzi.dbs.xml.transform.CachingTransformerFactory could not be instantiated: java.lang.NullPointerException
at org.vfny.geoserver.wms.WmsExceptionHandler.newServiceException(WmsExceptionHandler.java:65)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:865)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:528)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:315)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(
AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicatioFilterChain.java:215)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.p
rocessConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadP
ool.java:685)
at java.lang.Thread.run(Thread.java:595)
Caused by: javax.xml.transform.TransformerFactoryConfigurationError: Provider de
at javax.xml.transform.TransformerFactory.newInstance(TransformerFactory.java:109)
at org.geotools.xml.transform.TransformerBase.createTransformer(TransformerBase.java:70)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer.createTransformer(WMSCapsTransformer.java:123)
at org.geotools.xml.transform.TransformerBase$Task.<init>(TransformerBase.java:255)
at org.geotools.xml.transform.TransformerBase.createTransformTask(TransformerBase.java:144)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:125)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:105)
at org.vfny.geoserver.wms.responses.WMSCapabilitiesResponse.execute(WMSCapabilitiesResponse.java:87)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:516)
... 28 more
Kevin Gunn
Software Engineer
Australian Institute of Marine Science
Ph: (07) 47534305
Fax: (07) 4772 5852
E-mail: k.gunn@anonymised.com
The information contained in this communication is for the use of the |
individual or entity to whom it is addressed, and may contain |
information which is the subject of legal privilege and/or copyright. |
If you have received this communication in error, please notify the |
sender by return E-Mail and delete the transmission, together with any |
attachments, from your system. Thank you. |
-----Original Message-----
Sent: Friday, 16 May 2008 06:26 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Map Viewer Image
i have the same problem.
I'm using 2.2 on a Win server.
All seems to be good, except the map viewer which displays no image, non
map.
When i call http://localhost:8080/intermap i can't see the map too and i can
see the message Exception 'Object expected'
Please help
François-Xavier PRUNAYRE wrote:
Hi Bob, do you have any java exception in the log from geoserver
(something
dealing with epsg:4326 code missing somewhere ?)
Cheers. Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de
Jeroen
Ticheler
Envoyé : lundi 24 septembre 2007 15:35
À : Bob Nutsch
Cc : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Map Viewer Image
Hi Bob,
Check if the default map layers configured in ../web/intermap/WEB-INF/
mapServers.xml are pointing to valid map services. the default set of
layers is configured in that file.
Ciao,
Jeroen
On Sep 24, 2007, at 6:12 PM, Bob Nutsch wrote:
I just finished installing GN 2.1 with no apparent problems.
However, there
is no image in the overview map in the upper left of main page.
When I
click on the 'Open Map Viewer' link below where the map should be,
the map
image is also missing.
I am able to add a WMS to the Intermap view by clicking on the
green "Add
more layers" icon below the map. That image then shows up in the
Map Viewer
and in the overview map.
Is there supposed to be a default map showing up in a fresh
installation and
where/how do I set up a default map image?
Thanks, Bob
View this message in context: http://www.nabble.com/Map-Viewer-
Image-tf4509887s18419.html#a12862230
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-devel mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
View this message in context: http://www.nabble.com/Map-Viewer-Image-tp12862230p17261720.html
sender by return email and delete the transmission, together with any
