Hi
When attempting to perform a massive delete I get the following.
All records failed with the following.
"Metadata Records that could not be deleted because you are not the owner"
If I attempt to delete each record individually they are removed
successfully. But this is time consuming.
I checked the metadata tables for these records and found that the
groupowner field is assigned to a group that the user does not have access
to. But I am assigned content reviewer for the group in which the metadata
records belong to.
If I change the groupowner to be the same as the group for which I'm the
content reviewer then the delete works successfully.
1 - Why is the individual delete working but not the massive delete? Is this
a bug?
2 - The only way I know how to change the groupowner field for these records
is directly via sql commands on the database. Is it possible to change the
groupowner field via the interface? I thought the groupowner was
depreciated?
Using geonetwork 2.10.3
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/Massive-Delete-failed-tp5137511.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
