Hi Andrew,
Thanks for the info - yes, MD_Commons was introduced in 1.4 as a replacement for both MD_CreativeCommons and MD_DataCommons (it basically combines them into a single element).
If we switch the default schema to 1.4 in the schema plugins then they will all load as 1.4 records. If you want to fix the mapping to MD_Commons and version numbering (as well as schemalocation), it should be enough to run updatefixedinfo.xsl from the 1.4 schema on all your records - with a little bit of work this could also be done as a massive/batch xslt - best to open a ticket on this to make sure this is included and documented for MCP upgrades to 2.8.
Simon
________________________________________
Sent: Wednesday, 29 August 2012 11:17 AM
To: Pigot, Simon (CMAR, Hobart)
Cc: ianwallen; geonetwork-devel@lists.sourceforge.net; greg@anonymised.com
Subject: Re: [GeoNetwork-devel] MCP versioning Question.
Hi Simon,
I checked and our current production V1.4.2 MEST (installed 3/8/2010)
is using a pre 1.4 MCP version, like "MCP:BlueNet V1.3". The schema extension
file
that the production GN is using (attached) doesn't have a "mcp:MD_Commons"
element
type which I think was added for v1.4 so that narrows it down to pre v1.4
(correct
me if I am wrong?)
Actually if you read the comments in the header
of the schema extension file attached its a bit misleading because even though
its a pre V1.4 schema it says:
"This file contains extensions of the ISO19139 gmd schema
objects for the Australian Marine Community Profile Version 1.3-19139 and
1.4-19139"
I do recall being told around early 2011 when I started loaded all the metadata
that 1.4 or 1.5 would become the "official" schema. So following that lead
I set my gmd:MetadataStandardVersion to 1.4 or 1.5.
Actually I have at the moment:
"MCP:Bluenet version 1.5" - 1453 records
"MCP:Bluenet V1.4" - 308 records
Anyway, moving forward to the new 2.8 GN, lets be consistent,
they should all load as V1.4.
But how to to do this? Probably easiest for us is to do a massive
edit of the 'data' element in METADATA table in our Oracle db
changing the contents of gmd:MetadataStandardVersion to "1.4".
Tricky also because we would also have to update the
mcp:revisionDate element
and also the METADATA table 'change_date' to ensure our changes are properly
picked up by the AODN MEST harvestor. Sounds hard.
Could instead we craft some
kind of massive xslt that our V1.4.2 MEST could run?
Andrew
----- Original Message -----
To: <awalsh@anonymised.com>; <ianwallen@anonymised.com>
Cc: <greg@anonymised.com>; <geonetwork-devel@lists.sourceforge.net>
Sent: Tuesday, August 28, 2012 8:29 PM
Subject: RE: [GeoNetwork-devel] MCP versioning Question.
Hi Andrew,
Thanks for the suggestions - I think (correct me if I'm wrong) that we still
have the chance to use the version identifiers for 1.4 and 1.5-experimental I
mentioned in the response to Ian's email as most people using the MCP are
using MCP:Bluenet V1.3 in the BlueNetMEST 1.4.x software: they probably
haven't switched many records to 1.4 and/or 1.5-experimental as provided in
GeoNetwork/ANZMEST 2.8 as it is not yet production ready?
Cheers and thanks,
Simon
Sent: Tuesday, 28 August 2012 3:01 PM
To: ianwallen
Cc: greg@anonymised.com; geonetwork-devel@lists.sourceforge.net
Hello Ian and Simon,
Simon forgive me for commenting on this before your reply, but I
had come across a similar issue to Ian, so Ian thanks for raising this.
I also get metadata import as MCP-1.5 when I guess it's really MCP-1.4.
Our production GN at http://www.metoc.gov.au/geonetwork has used 2
different <gmd:MetadataStandardVersion>,
i.e we have not been consistent:
"MCP:Bluenet V1.4"
Now the schema detection logic says :
IF MetadataStandardVersion=1.4 then load up as MCP1.4 record
ELSE Default to MCP1.5 record
So all of our existing MCP metadata records are going to end up as MCP1.5
on import to the newer 2.8 ANZMEST-GN. However maybe this unintended
version/schema
upgrade (1.4->1.5) is not such a bad thing because anything that is V1.4 is
valid
with the 1.5 schema.
Maybe its necessary to make the schema detection logic smarter i.e anything
with '1.4' as a sub-string gets MCP-1.4, anything with '1.5' gets MCP-1.5 and
anything not recognised defaults to MCP1.5. Any thoughts on this?
Looking forward to your replies....
Andrew
PS: Ian,
I agree with what you are saying about the inconsistencies.
'MCP:BlueNet V1.4' is better than just '1.4'
To: <geonetwork-devel@lists.sourceforge.net>
Sent: Monday, August 27, 2012 9:48 PM
Subject: [GeoNetwork-devel] MCP versioning Question.
Simon,
Is there a reason the 1.4 version of MCP is labeled (within
gmd:metadataStandardVersion) as "1.4" while the 1.5 is labeled as
"MCP:BlueNet V1.5". Shouldn't the 1.4 be labeled as "MCP:BlueNet V1.4"
Also, there also seems to be some inconsistencies...
The following use "MCP:BlueNet V1.4"
convert/OGCSOSGetCapabilitiesLayer-to-19139.xsl
convert/OGCSOSGetCapabilities-to-ISO19119_ISO19139.xsl
And the following use "1.4"
schema-ident.xml
update-fixed-info.xsl
template/thredds-harvester-unidata-data-discovery.xml
Here is a suggested patch if you agree that it should be named "MCP:BlueNet
V1.4"
http://osgeo-org.1560.n6.nabble.com/file/n4998050/mcp_1.4_version.patch
One of the issues that I was encountering is that I cannot add an MCP 1.4
document to geonetworks via the file upload unless the versions matches
within the schema-ident.xml (otherwise it defaults to a MCP 1.5). All the
MCP records that I currently have use "MCP:BlueNet V1.4" within
gmd:metadataStandardVersion. They were all created with Bluenet MEST.
Although it is possible to change them from "MCP:BlueNet V1.4" to 1.4, I
would like to hear your input.
Thanks.
View this message in context:
http://osgeo-org.1560.n6.nabble.com/MCP-versioning-Question-tp4998050.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
geonetwork-devel List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
