[GeoNetwork-devel] MEF 1.1 or 2.0 used in latest mef.import?
  Which MEF file version is the latest trunk build of GeoNetwork using in its MEF Import service (../geonetwork/srv/en/mef.import)?
My MEF insert ETL script stopped working with our last GeoNetwork upgrade (build 5825). We use MEF files for bulk loading of metadata records because the CSW insert was too slow, unreliable, and required additional, manual steps (permissions, icons, etc.). I would like to know if our "home made" MEF files need to be upgraded to the 2.0 format or if there is a bug somewhere else.
BTW, where can I find the specifications for MEF 2.0? I only found a proposal at http://trac.osgeo.org/geonetwork/wiki/MEFImprovement
Ciao, Wolfgang
_______________________________
Wolfgang Grunberg
Arizona Geological Survey
wgrunberg@anonymised.com
520-770-3500
Hi Wolfgang,
2010/7/19 Wolfgang Grunberg <wgrunberg@anonymised.com>:
MEF 1 should be supported by the service (the service try to detect
which version is coming in). What kind of errors did you get ?
Basically MEF2 is a collection of MEF1 with one directory for each
metadata record (with profil and iso19110 records embedded when
available).
Cheers.
Francois
Ciao, Wolfgang
Wolfgang Grunberg
520-770-3500
This SF.net email is sponsored by Sprint
What will you do first with EVO, the first 4G phone?
Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
GeoNetwork-devel mailing list
  Hi Francois,
It has been a while since I ran my import scripts. I remember the error message to be pretty generic.
I will get back to you once I have compiled a new version and test again.
Ciao, Wolfgang
Wolfgang Grunberg
520-770-3500
On 7/19/2010 12:32 PM, Francois Prunayre wrote:
Hi Wolfgang,
2010/7/19 Wolfgang Grunberg<wgrunberg@anonymised.com>:
available).
Cheers.
Francois
Ciao, Wolfgang
Wolfgang Grunberg
520-770-3500
