[GeoNetwork-devel] metadata conversion
Dear list,
I have a question for you.
Is it possible do a conversion of metadata from dublin-core to ISO19139 standard and from fgdc-std to ISO19139 standard, like ISO19115_TO_ISO19139?
Thank you.
Federico.
Hi Federico,
I can't comment on the FGDC to ISO 19139 but I can comment on the DC to
ISO 19139. We (Australia and New Zealand) tried to do a mapping when we
developed the ANZLIC Metadata Profile of ISO 19115 and ISO 19139.
During that process we found that ISO 19115/19139 was very detailed and
could be mapped into DC general elements. However, when we tried to map
from DC to ISO 19115/19139 we found that it wasn't possible to break up
the general DC elements and map them to the specific ISO 19115/19139
elements. In fact most of the DC elements could map to multiple ISO
19115/19139 elements and hence needed human intervention to determine
which element they should map to.
Having said that, there are some basic elements that do map such as
topic to keyword, title to title, description to abstract, etc.
I don't know of an XSL that does the translation.
I hope that this helps.
John Hockaday
-----Original Message-----
From: federico marottoli [mailto:federico.marottoli@anonymised.com]
Sent: Wednesday, May 30, 2012 2:22 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] metadata conversion
Dear list,
Thank you.
Federico.
The information contained in this e-mail, and any attachments to it,
is intended for the use of the addressee and is confidential. If you
are not the intended recipient you must not use, disclose, read,
forward, copy or retain any of the information. If you received this
e-mail in error, please delete it and notify the sender by return
e-mail or telephone.
The Commonwealth does not warrant that any attachments are free
from viruses or any other defects. You assume all liability for any
loss, damage or other consequences which may arise from opening
or using the attachments.
The security of emails transmitted in an unencrypted environment
cannot be guaranteed. By forwarding or replying to this email, you
acknowledge and accept these risks.
Dear list,
For the GEOSS Clearinghouse system we convert any remote FGDC metadata into ISO 19139 on ingest to create the same style records for search. This is done by linking in an XSLT to the ingest routine for our version of GeoNetwork. The XSLT is available from NOAA:
http://www.ncddc.noaa.gov/metadata-standards/metadata-xml/
The conversion does a best-possible (acceptable) mapping between the two standards which are of similar detail.
Doug.
Thank you.
Federico.
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat Tel/Fax:+1 503 454-6248 Cell:+1 703 459-5860
