[GeoNetwork-devel] metadata.edit access by uuid
Hello,
it seems that the metadata.edit webservice is lacking of an access via uuid parameter, allowing only to be called via the internal GeoNetwork identifier ; here is a patch which should allow the call of metadata.edit using the uuid as parameter. I just tested and it seems to work fine, but if there is any reason why the previous behaviour was preferred (and if there is a good reason why the edit service is not supposed to be called using a uuid), I will be glad to ear for your feedbacks.
Pierre Mauduit
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)4 79 44 44 92
http://www.camptocamp.com
pierre.mauduit@anonymised.com
(attachments)
GetEditableData.patch (786 Bytes)
Applied to trunk, Pierre.
Cheers.
Francois
2011/1/3 Pierre Mauduit <pierre.mauduit@anonymised.com>:
Hello,
Pierre Mauduit
Learn how Oracle Real Application Clusters (RAC) One Node allows customers
to consolidate database storage, standardize their database environment,
and,
should the need arise, upgrade to a full multi-node Oracle RAC database
without downtime or disruption
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-devel mailing list
